1978 - 1996 Big Bronco
302 H.o.!?
Old Oct 6, 2003 | 09:27 PM
bronco 1996 16 year old's Avatar
Question 302 H.o.!?
I had never heard of it before but when i did a vin check on my Bronco it came up as having a 302 HO. I was confused because I had only heard of the HO being in t birds and mustangs not in broncos. So i looked into it and i found the fireing order for the 351 and 302 HO was 1-3-7-2-6-5-4-8 which was the exact same as the fireing order in my bronco. So now im shure i have the HO. Now what i want to know is if anybody knows the horsepower difference between the 2 engines and if anybody else has this engine in their bronco.
Old Oct 7, 2003 | 12:20 PM
Doorgunner808's Avatar
Doorgunner808
The HO was also found in the Crown Vics, I don't know that much about them though hopefully someone out there does cuz I am kinda curious about it myself as I have an EFI motor from a Mustang GT for my 78 Mustang that is not an HO.
DG808
Old Oct 7, 2003 | 08:25 PM
Come on who on here knows about 302 H.O engines. their has got to be someone.
Old Oct 7, 2003 | 08:36 PM
Torky2's Avatar
Torky2
I never heard of a 302 HO FUEL INJECTED engines as an option in the Bronco. Not saying it isn't possible, but funny I never saw or heard of one before. What is your Engine Code digit in the VIN ?
Can you post a picture of your engine somewhere?
Old Oct 7, 2003 | 09:49 PM
BigRyanKP's Avatar
BigRyanKP
the only cars that i know of that came with the true HO engine was the mustang and the lincoln mark vii, the cougars, t-birds etc said HO on them but wern't true HO's. I'm not sure however for the bronco engine the firing order could be the same but it may not be a roller motor and i think the tb is a little small. i'm still not sure though, I tried to find specs on it and i found that it has 205 hp (HO engines have 225) and something like 275 or 280 torque which is almost the same as the HO engines.
Old Oct 8, 2003 | 09:37 AM
Well i went to my local motor sports shop and they did a free dyno test for me and it turned out i have 230 hp at the wheels at 4200rpm's and 295 ft lbs of torque. All i have done to my bronco is take out the muffler and hollow out the second cat. so if mine is a HO i got 5 extra hp and if it is not i suggest to everyone who has a 302 to do some exhaust work. But maybe the torque was higher because of the gears in the mazda 5 speed i have but i sort of dobut it. Thanks for all the help (again)
by the way i will have some picts of my bronco for you all to take a gander at.
Old Oct 8, 2003 | 07:31 PM
89bucknbronc's Avatar
89bucknbronc
Did you take the muffler off entirely and hollow the second cat, and run a straight pipe? I cut my exhaust off at the back of the second cat and had a muffler shop run a straight pipe in front of the rear wheel. I didn't mess with my cats, thought it might be to loud, but it sounds good and has a powerful tone.
Bad1993
Mar 19, 2017 06:44 AM
frankosd
Engine Swaps
Nov 14, 2016 10:09 AM
telemaster444
Engine Swaps
Sep 16, 2016 08:55 AM
James888
13
Jan 20, 2016 02:13 PM
spaceganja
Nov 12, 2003 10:29 PM
