302 firing order help
on
There is no good way to determine the firing order with absolute certainty because the cam could have been changed at any time in it's life, and the cam determines which of the 2 firing orders the motor uses. In general though most motors built before 1994(Mustang excepted) had the old firing order and all built after that date used the HO firing order. Look for the block and head casting numbers to determine the relative vintage.
Received 4,116 Likes
on
on
Well the truck was running with the ho order
But I just wanted to clarify
I saw the non ho order on the manifold so I thought I'd just try the wires in that order for peace of mind so put them to the order cast in manifold and it didn't run properly
on
OK very good.. you didn't mention you were able to run the motor and I didn't want to assume, that is certainly a good way to verify. Problem now is that also confirms you have a mix of older and newer parts or possibly an aftermarket cam. Did you find any casting numbers? If you have a late model engine you may find some capital letters cast into the heads on the very outside corners near the valve covers, these letters can help ID the heads and possibly the general vintage of the engine.
Yes I understand the mix up of parts as its not an original car
I'm guessing maybe the engine is a injection engine?? With a carb manifold maybe if there was such a thing?
on
Yes it's possibly you have a late model EFI motor with a carb on it which would be a big bonus if it's a roller motor, the 302 block and heads never changed in terms of bolt patterns so you can mix and match just about any vintage of parts. To tell if it's a roller simply remove a valve cover and shine a light down one of the pushrod holes, if you can see a fork looking device around the base of the lifter you have a roller. You may have to remove a rocker and pushrod to do this, but pedestal mount rockers are simply torqued down so you don't have to worry about messing up lifter preload.
P.S. If you go that far... before reinstalling the rocker put a dial gauge on the pushrod after it has been inserted into the lifter and crank the motor through a revolution by hand to measure lobe lift, this can then be used to figure out if the cam is stock and if so which one it is.
Thanks for your advice
It's only got a two barrel carb on it tho ??
Ratsmoker
04-26-2004 05:32 PM
