I have a 2005 F150 and the a/c will come on by itself when I have the switch in the off position. It doesn't matter if driving or just cranking the truck if it decides to come on it will. I can turn the blower motor switch on then back off and it cuts off and it might not come on again for days ,weeks or months. Where would I start to look for trouble at.
if the blower starts up with the switch in the OFF position, I would look at the switch or the resistor that sets the speed...
I think the resistor set is in the air duct under or behind the glove box. You can lay on the passenger floor and look up to see a small cube with a 4 wire harness connected to it... normally it screws to the air duct......... at least all older trucks were made that way and I assume the 2005 is similar.
Does the ac clutch come on and also the blower .There is a clutch relay on drivers fender that signals the clutch . If both the clutch and blower coming on its most likely the ac control module .The pcm overviews some of the ac controls such as pressure switches . Perhaps someone has disturbed wiring working on head unit or radio . But most likely a junk yard control unit may be a good starting point . I have some diagrams on my other computer but I have not delved into the different ac controls. I have the lariat auto control and everything is still working at 206 k . Your control must be issuing this command in my opinion at this distance .
I know the clutch relay does not control the blower . I was just pointing to check points and explaining my guess how most systems work . If clutch and blower coming on then its most likely the ac control doing it . I really don't have enough info at this point .The pcm has a lot of overview on most of these .Since the area of the ac control is next to the audio unit it gets some unwanted attention to modifications . So many times you hear later I was putting this mod on and then !!!! But not a word about it until much later . But boy have I seen some wiring backfeed disasters.
The 1&done original poster said that the “a/c” comes on by it self.
I assume he is referring to the a/c compressor.
Doesn’t the PCM cycle the a/c compressor when the starter first starts to crank the engine?
I don’t know, but I *think* I read that someplace.
You're thinking of the CASS (Compressor Anti-Slugging Strategy) found in a number of Ford products.
The WSM describes it as follows (from the '05 F150 manual):
Liquid refrigerant may accumulate in the A/C compressor under certain conditions. To alleviate damage to the A/C compressor, compressor anti-slugging strategy (CASS) is utilized.
CASS is initiated only under specific conditions:
the ignition is off for more than 8 hours
the ambient temperature is above -4°C (25°F)
battery voltage is above 8.5 volts during engine cranking
When these conditions are present, the powertrain control module (PCM) will activate the A/C control relay prior to cranking of the engine. The A/C control relay engages the A/C compressor for approximately 4-15 A/C compressor revolutions or a maximum of 2 seconds (depending upon vehicle application), allowing the liquid refrigerant to be pushed from the A/C compressor. CASS is initiated by the PCM regardless of the function selector switch position or the EATC system settings.
