Drivers door harness
Old Aug 12, 2019 | 12:04 AM
wa-sleeper's Avatar
wa-sleeper
Is the wiring harness plugged in at the door jam or does it run through? And if it's a plug is there a way to unplug it or is it clipped in? I need to fix the power rire to the wi does so I was goi g to take the door panel off and pull the harness through so I do t have to try to wire it in the door jam.
Old Aug 12, 2019 | 07:42 AM
redfishtd's Avatar
redfishtd
I don't believe thats efficient. Pulling a replacement wire thru for the one or two wires that are in trouble with good splices seems much easier . You probably won't get a color match either.,so many different factory colors . If you use one color wire for three or four then put numbers on each end wires for future and for self checking .
