vacuum tree
Old Oct 6, 2003 | 04:33 PM
ford429cu's Avatar
ford429cu
vacuum tree
I'm having a serious problem with the vacuum tree loosening up on my 67 390 after about 20-30 mins of the engine running. I have been putting teflon tape on the vacuum tree to ensure it doesn't leak, is that my problem of why it keeps lossening? If not what should I do?
Jeff
Old Oct 6, 2003 | 05:22 PM
Ratsmoker's Avatar
Ratsmoker
Never heard of that. How much torque are you putting on it? I used teflon on mine but it probably isn't all that necessary. You could put the teflon about halfway up the threads and put a small bit of loctite on it. I wouldn't get carried away with the loctite though.
Old Oct 6, 2003 | 10:32 PM
Putt's Avatar
Putt
Could be that the threads on the tee or in the intake are worn enough that they don't grab well anymore. Pipe threads are a friction fit. Loctite makes a pipe sealant that is also a thread locker, called PST part number 592 for a small tube.
Old Oct 7, 2003 | 11:06 AM
rebocardo's Avatar
rebocardo
Mine is loose again too and I tried the pipe sealant, it did not work for long. I think maybe the heat destroys it. I have a 1965 390 in my 1971. I am starting to think red lock-tite.
Chester_field
Feb 26, 2017 09:53 PM
sandymane
Feb 23, 2017 04:20 PM
jaleus
Feb 15, 2017 09:33 PM
45FMJoe
Oct 30, 2016 10:23 PM
grandpas1974
Apr 8, 2016 11:34 AM
