429 ?
Old Aug 1, 2019 | 08:05 PM
50fps's Avatar
50fps
429 ?
I have a line on a 1970 429 with DOVE heads out of a Thunderbird. Supposedly runs good (still in vehicle), not an oil burner and complete.
So I was thinking of picking it up and going through it along with some mods, then pulling my 460 and throwing the 429 in my 84 F250.
Take the 460 and freshen it up for a back up or sell out right.
My question is what type of prices are decent stock 429 engines going for these days?
Old Aug 2, 2019 | 09:30 AM
jas88's Avatar
jas88
Why spend money on an engine with less displacement if you are going to "go thru it" anyway? Why not just treat your existing 460 to a freshening and leave it at that? It would be much cheaper that way and you don't have an extra motor laying around taking up space. There is nothing magical about a 429 vs a 460 in this application except perhaps higher compression which may require premium fuel.
Old Aug 2, 2019 | 04:50 PM
50fps's Avatar
50fps
I see your point. I already run premium in all my vehicles, despise the ethanol mandates and subsidies. The only reason I am considering this is because out of the box the 70 429 has a hundred +/- more on each end than the 84 460 in stock configuration. To bring the 460 up to the stock specs of the 429 it could possibly add up to more than what a mild mod on the 429 could achieve overall. All would be dependent on the internals of both engines.
Old Aug 4, 2019 | 09:33 AM
jas88's Avatar
jas88
If you are talking about HP & Torque, you need to remember that the measuring standard was different in 1970 vs 1984. In 1970 they used gross numbers but, starting in 1972, they switched to net numbers. Everybody's numbers dropped drastically in 1972 and it was not due to stricter emission controls, as many people assume.
Here in Texas, all grades have 10% ethanol, not just regular.
derryckwait
Engine Swaps
Mar 17, 2011 10:27 AM
zrxlover
20
Aug 29, 2010 02:30 AM
danwalker20
19
Apr 30, 2007 08:19 AM
BubbaF100
Feb 23, 2000 05:03 PM
