Speedo problems with E40D
Old Apr 24, 2015 | 10:50 PM
thundair's Avatar
thundair
I have a 1971 F250 with an E40D overdrive transmission with a 72 F500 dash.
I replaced the tail shaft with a geared piece and I have the proper cable and 17T gear all hooked up correct
I can see the cable turning at the dash but the speedometer bounces on zero.
I took the speedometer in to a shop and it got a clean bill of health.
My conversation with the speedometer guy is to put a gear conversion on it and change the speed sensor for something else.
I also talked to Baumann Transmission and his thinking is the speedometer should be reading something if the cable is turning.
Now I don't have any idea of what to do next
Any help would be much appreciated
Thanks
Old Apr 24, 2015 | 11:06 PM
HIO Silver's Avatar
HIO Silver
Which speedo cable is being used?
I'd compare the diameter of the speedo cable... not the jacket or sleeve but the actual cable itself. It might be too small in diameter and is barely driving the speedo gauge.
Old Apr 25, 2015 | 11:07 AM
thundair's Avatar
thundair
I measured the cable square drive it is .120
I have a loose cable with the same dimensions and I can spin the speedo up to about 50 MPH with a drill on the loose cable. The one in the truck seems slow but I don't know why.
Old Apr 25, 2015 | 11:51 AM
Gembone's Avatar
Gembone
is the drive gear installed backwards? Thus spinning it towards zero. Does the speedo work in reverse?
Old Apr 28, 2015 | 04:16 PM
JEFFFAFA's Avatar
JEFFFAFA
2x Greg. Sounds like you have the wrong speedo driven gear. Or both drive and driven gears are spinning the cable the wrong way.
rashanny
24
Mar 31, 2011 11:14 PM
ol orange
Aug 14, 2010 12:48 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
64fordf100292
Sep 16, 2007 07:20 AM
GT40Cougar
Jul 26, 2004 02:39 PM
