Buzz Test question
Old Aug 27, 2019 | 01:04 PM
  #31
chasteen1156's Avatar
chasteen1156
Well I am back from vacation and back to this truck issue. After reading all the good advice here and searching all the threads relating to this issue I came to the conclusion it could only be the connector to the IDM. I had good Ohm tests from there all the way through the injectors and back, known good IDM and PCM, and still it was only running on 4 cylinders. I took a probe and checked the IDM connector and it seemed that #23 on the connector was a little larger than the rest. I took the connector apart and squeezed that one connection a little tighter. I then reassembled it and plugged it back in to the IDM and the truck fired right up and is running on all 8 cylinders. It has some other issues but I will open another thread for that one so as not to confuse things. Thanks for all your help with this issue. This is really a great forum. I have learned a LOT about my 7.3 that I did not know.
Old Aug 27, 2019 | 01:14 PM
  #32
FordTruckNoob's Avatar
FordTruckNoob
Good to hear you got this one sorted. Now go post up your other issues with the truck so we can help there.
Old Nov 4, 2025 | 03:02 AM
  #33
Thamaxx118's Avatar
Thamaxx118
4th Gear
Correct they all will do that. everyone I've tested
Old Nov 5, 2025 | 07:45 PM
  #34
Mdkeehn13's Avatar
Mdkeehn13
4th Gear
Originally Posted by chasteen1156
2001 F250 7.3 PSD 180,000 miles on it. It is only running on 4 cylinders. I have replaced the UVCH with a brand new one from Ford. When I run a buzz test I get P1294 High Side open on the left bank. I have replaced the IDM with a known good one. I have replaced the PCM with a known good one. The buzz test shows that cylinders 2,4,6 and 8 are weak. However I disconnected the UVCH and ran the buzz test again and all 8 buzz but still 2,4,6,and 8 show weak. How can they even buzz at all if the harness is unplugged? I have ran the ohm test also and all the injectors show good with no shorts. I am about out of ideas. I have read many threads on this forum and cannot find any other ideas. Oh, I also took the wiring harness completely off the engine and checked the whole thing and wired in a new UVCH connection from Ford while I was at it. Any ideas?
how do you perform a buzz test, if you don't mind taking the time to reply. TIA
Old Nov 5, 2025 | 09:27 PM
  #35
JoshHefnerX's Avatar
JoshHefnerX
It's one of the tests inside Forscan. There's a sticky thread or 2 at the top of this forum on Forscan. The pc software is free- but you need an obd dongle - they're pretty cheap.
Old Nov 5, 2025 | 09:37 PM
  #36
Mdkeehn13's Avatar
Mdkeehn13
4th Gear
thank you, much appreciated
akorcovelos
Jul 13, 2024 03:01 AM
pstrokemike97
Mar 15, 2019 09:52 AM
Tsprague706
Jan 27, 2017 09:48 PM
dieselsubmariner
29
Nov 29, 2012 07:24 AM
johnguc
16
Oct 30, 2006 06:35 PM
