Exaust Manifold
Old Oct 6, 2003 | 02:37 PM
gondothegreat's Avatar
gondothegreat
Angry Exaust Manifold
Well, after trying to order a new left exhaust manifold from ford for a '94 3.0, it turns out that they made some with the EGR and some without.
I happen to have one w/o EGR....The exhaust manifold is no longer available from Ford....You can however get one for an engine with EGR...(of course it costs more).
I will now have to check junkyards for this part. I don't think I will have much luck due to rust..but I will still look. I am also going to see if I can hook up a EGR valve.
just thought I'd share....
Old Oct 6, 2003 | 04:13 PM
ctfuzzy's Avatar
ctfuzzy
Seek Revenge on Ford.
!! Install Headers Instead !!
Old Oct 6, 2003 | 05:40 PM
wolfen's Avatar
wolfen
Hi gondothegreat,
I would find out what the ID size of the hole is using a dial caliper machinist tool + go to a plumbing supply house + find a sutable plug or whatever it takes to seal this hole, even welding it! How's
your luck? Finding one in the bone yard?
__________________________
The brain is always on the move!!
Do whatever it takes to get the job done / won!
Old Oct 10, 2003 | 07:32 AM
gondothegreat
haven't had any luck so far.....
I would buy headers, but they cost too dang much.
I've also been trying to find a gasket, not with any success though.
Out of curiosity, would any of the 'create-a-gasket' items work for this application. I know there will be extreme heat, and just curious if there is anything that could handle it. I really don't want to spend too much more that $150 bucks on this. I can deal with the noise until the truck dies.....160k on her now. everything else is running great.
Old Oct 10, 2003 | 11:23 AM
amp17757's Avatar
amp17757
I would find it hard to believe that there aren't plenty of good junkyard manifolds around. Do a little "leg work" ... I'm sure you'll be glad you did. Since you obviously have access to a computer, check the web for used parts too.
Old Oct 10, 2003 | 01:39 PM
gondothegreat
I'm guessing that they've made more of these engines with the EGR. That is all I have been able to find. I know I still have a few options, but just trying to make it cheapest and easiest as possible...
I've done some searching on the internet, if you know of any sites that offer used parts like that, it would be great if you could let me know.
Old Oct 10, 2003 | 01:46 PM
amp17757's Avatar
amp17757
I'll keep ya' posted............
AAubinoe
Jul 31, 2014 11:28 PM
Fordenthusiasts
16
Feb 1, 2010 05:06 PM
larry57
Dec 1, 2009 04:26 AM
jfarcas
Jul 29, 2006 03:23 PM
etcetera
Modular V10 (6.8l)
Jan 3, 2005 09:27 PM
