Water pump questions
Old Jul 29, 2019 | 12:31 PM
pkthomas's Avatar
pkthomas
I am not quite finished with replacing the water pump on my 2000 excursion 7.3.
1. What is the spec for the short water pump bolts? I lost one.
2. What is the spec for the thermostat housing bolts? One broke.
3. How do I know if the fan to water pump is right enough? I rented the tool but not sure if I got it tight enough.
Old Jul 29, 2019 | 01:20 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@akcooper9 had a similar experience to yours a while back and may be able to provide some advice.
Hopefully he will be along shortly.
Old Jul 30, 2019 | 02:57 PM
HD Rider's Avatar
HD Rider
For the fan, just snug it down. It's designed so engine torque and load keep it tight. It you tighten it up to much, you'll have a hell of a time ever getting it off again.
Old Jul 30, 2019 | 06:07 PM
Jo7.3's Avatar
Jo7.3
I got my torque specs from this article. Didn't break a bolt and don't have any leaks so I guess they're right. Only thing is the thermostat housing bolt torque contradicts itself...it says 11 ft lbs or 110 inch lbs. I just went with 120 in lbs and that seems fine.
https://deadheaddiesel.com/7.3-power...ter-pump-leak/
As for the fan...I loosened it by holding an Inch and 7/8ths wrench on the nut, then had my helper give the wrench a couple good whacks which broke it loose. To tighten the fan nut, my helper and I threaded the fan back on all the way until it was spinning the pulley. Then I put the belt back on to help hold the pulley. Lastly, I held the wrench on the fan nut while my help gave it a couple of good whacks to tighten it. Haven't had any problems yet.
Old Jul 30, 2019 | 09:46 PM
pkthomas's Avatar
pkthomas
Thanks for the info. I probably got the fan tight, I hope.
Has anyone used an aluminum thermostat housing?
Old Jul 31, 2019 | 01:18 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Not sure if it qualifies, but I've had one on the shelf for like 5 years.
Word is they are better than OE because the stamped steelies deform under torque and are rust-prone. But you need to use a thermostat with the correct o ring with the aluminum version. And a thin bit of RTV on the o ring is not a bad idea. I'll put it on when it comes time for a new pump.
As HD Rider alluded to the fan will self tighten due to crank rotation. If it's on there it's fine.
Did you resolve the broken thermostat housing bolt? Got an "around the belt" top coolant hose?
Old Jul 31, 2019 | 07:51 AM
pkthomas's Avatar
pkthomas
My truck has always had the around the belt hose. The aluminum housing I am looking at comes with bolts, problem solved.
Thanks to everyone for the responses.
gneill794
Oct 25, 2008 08:45 PM
NS F250
18
Jul 22, 2007 11:15 AM
Bubbatruck
Feb 23, 2006 04:13 PM
Skeeterzx200
Nov 22, 2005 03:22 PM
txskeeter
Jul 18, 2002 11:09 AM
