water pump replacement
Old Jul 17, 2002 | 02:58 PM
txskeeter's Avatar
txskeeter
Looks like I need to replace the water pump. Any pointers, as I have never done this before. I have a 1993 4.9. The shop wants $175.00. The part is about 30 bucks. I have changed the thermostat before though. Thanks
Old Jul 17, 2002 | 03:11 PM
SPROCKET's Avatar
SPROCKET
WHOA..I'm going through the same problem...
I replaced the t-stat a few times, all the hoses, new clutch i just replaced the water pump and flushed the radiator a few times and still nothing...it's either my timing or radiator is bad.
when I took the fan off to get to the water pump and just stuck a wrench on it..I forgot the size, and i gave it a few taps with a hammer while I was trying to hold the wrench so it actualy didn't move. If you just try pulling it with the wrench it will just move around and around...so you need to put the wrench on and hold it(the wrench) kind of tight at the top and give it a few solid taps toward the left, the vibrations will break it loose.
1.Remove 3 bolts off the fan, leaving one to hold it in place.
2.Remove 3 bolts off the pulley and leave one to hold it in place.
3.Align the 1 bolt on the fan and the 1 bolt on the pulley so they are facing eachother and turn them so the are out of the way(turn them so the are at the bottom of the fan and pulley), if you look straigt down you shouldn't be able to see them because they would be hidden from the big nut in the center holding the fan clutch.(get it?)
4.Put the wrench on the nut and give it a few taps like i explaind above.
The nut it actualy part of the clutch so they won't seperate as it might apearre.
Old Jul 17, 2002 | 03:25 PM
txskeeter's Avatar
txskeeter
I appriciate the feedback...I will give it a shot.Gotta try before I drop 175 on it! Thanks
Old Jul 17, 2002 | 04:18 PM
jacoby's Avatar
jacoby
If you get the tool then it is a piece of cake. Just watch your nuckles. I got one for checker on there loaner program and it worked fine. Best of luck.
Jacoby
Old Jul 18, 2002 | 11:09 AM
TallPaul's Avatar
TallPaul
