95 Ford E350 7.3 Restart issues
Old Jul 27, 2019 | 01:00 PM
67camaro's Avatar
67camaro
Ok The van will fire up after it sits for like 3 hours Does not matter how long you run it 5 minutes 1 hour same symptom
Runs great when running no hard idle , step on it and it does not hesitate
Here what is new in the vehicle for the last 2000 miles
Factory ford parts Whole new filter filter assembly, New fuel pump, New water fuel separator filter, Vacuum pump
Tank is full of fuel, RUN SHELL DIESEL. Batteries are year and 4 months old, No cranking issues, Tested the volts batteries at 12.15 to 12.18 standing
When running 14.75 at idle Was a former Fire dept Van Heavy duty Alternator
Oil level is fine and clean, Change every 5000k No check engine light, No codes Yet
Now Will A CPS CAUSE THIS TYPE OF ISSUE AFTER SHUT DOWN HAVE A FACTORY UPDATED FORD COMING
Old Jul 27, 2019 | 10:01 PM
z31freakify's Avatar
z31freakify
So it doesn't restart in the period of time? Just trying to figure out what you are trying to ask.
Old Jul 27, 2019 | 10:46 PM
67camaro's Avatar
67camaro
Reply to clarify
Ok After like 4 hrs it will fire up and run fine
Tried a new CPS tonight, starts like normal after it sat for like 6 hrs
Drove it like 15 minutes Runs great no rough idle no hesitation
Pulled in my driveway let idle few minutes Shut off Tried to restart
Same issue cranks no start, no smoke
Old Jul 28, 2019 | 06:10 AM
427 fordman's Avatar
427 fordman
I'd pull the ipr and check the orings.
Old Jul 28, 2019 | 09:02 AM
z31freakify
Might be failing IPR coil, before this happens wet a rag and put it on the freezer, when it does it again get that cold rag from the freezer and put it over the IPR coil and let it cool off and try and restart your truck, if it starts you have a bad IPR coil.
Old Jul 28, 2019 | 10:40 AM
67camaro's Avatar
67camaro
Thanks for the tip It is a E350 van and Ford crammed everything in there Just to get to the IPR I have to take the whole air intake off I think to access the IPR To try the test with the rag? Might want to spend the 160 on the part If I do the disassemble work The van only has 100k Now I would think Its PO being the fire dept would of kept up on oil changes Bought it with 87K I have had it for 13k I have done 3 oil services already, use Ford filters
Do the IPR fail due to heat? Or dirty oil ? I am in So Cal
Old Jul 28, 2019 | 10:43 AM
67camaro's Avatar
67camaro
How long do IPR last ? 100k on the van Know any good scanner apps and blue tooth sender
z31freakify
Its for it to cool the IPR coil, you could put cold water on it but with a hit engine ehhh you might end up cracking a block or something you know.
Old Jul 28, 2019 | 02:23 PM
867.309's Avatar
867.309
The most bang for your buck:
https://www.ford-trucks.com/forums/1...the-cheap.html
Go to the no start flowchart in the FAQs for this forum and follow it.
Old Aug 3, 2019 | 01:22 PM
67camaro's Avatar
67camaro
Tried the rag trick no avail nothing changed
Old Aug 3, 2019 | 03:37 PM
Pickledboater's Avatar
Pickledboater
Mine did the same thing, it was the IPR o-rings.
Old Aug 3, 2019 | 03:39 PM
Pickledboater
Mine did the same thing, it was the IPR o-rings. If I remember it was at around 200k miles and it happened all of a sudden.
BigJake34452
May 1, 2012 04:08 PM
eggturner
95
Oct 20, 2010 10:08 PM
gordeaux
15
Jun 17, 2007 08:06 PM
YellerMax
24
Dec 11, 2006 06:31 PM
Mel G
Jun 5, 2006 11:59 AM
