well jb weld probably won't cut it ,if it is made out of steel you and maybe braze it back on but you have to take the glass out of the frame also the bottom frame pin looks like it is missing also may be best to find a good used one some where
good luck mike
Those things are cast zinc alloy and are part of the window frame. They aren't available separately as far as I know. Also they require a special rivet to attach them. I know the re-pop frames are expensive a good used one is an option if you can find one.
I just replaced the frames on my vent windows. It's not as hard as it looks, so don't be afraid to take it all apart.
Carefully pry the glass out of the vent window channel first, then you can loosen the pivot nut inside the door. The new vent window frames come with new hardware so it's not a big deal if the shaft snaps off when your trying to take it off.
You will probably want to take the new vent window along with the glass to a glass shop so they can press the glass into the new frame with glass setting tape.
The bracket is a different piece than being discussed in Post #1 - the vent window has the pivot nub on it that the bracket 21465 sits in. See picture #3 in Post #1
The left side of this bracket sits in the hole in picture #3.
So basically...C3TZ-8121465-A is the replacement number for the part I need.
Cool...thanks.
You might want to re-read that again. If you are asking if the piece that broke off of your wing window is the same part as the bracket in my picture I've already indicated in the post that you replied to that it is different.
That was mostly for the sake of Bill NumberDummy since he assumed that the bracket was the part being discussed.
Thanks for that. Which is my biggest problem...reading, comprehension and putting that to use. I appreciate you clearing that up for me.
Not bad - I tend to be a bit dyslexic myself - which vent window frame did you need, is this the right hand passengers side? I can see if I have a good used one here and if so I'd only ask shipping.
That is awesome of you. Not trying to hijack here, but if you happen to find a second one for the driver side, let me know what you would ask for it please. Mine is broken on the top and bottom and held in by gorilla tape for now.
