Sponsored by: Auxito
4x4 grease seal
Old Jul 24, 2019 | 07:51 PM
96f150's Avatar
96f150
4x4 grease seal
So ive had this rub rub sound for a while now. I ended up replacing both my front cv axles as well. I noticed that there is some sort of grease seal the protects the back side of the sealed bearing....My question is, does that come with a new hub bearing assembly when you get one? For soem reason mine is extrememly dry and brittle on the drivers side.....maybe a stuck caliper at some point prior to me owning it
Old Jul 25, 2019 | 09:09 PM
steve(ill)'s Avatar
steve(ill)
Don't think you get a new one with the hub... I have also seen many that are hard / cracked... It basically keeps water from getting to the backside... look close, it don't do much... I have put a couple back together with bad seals when not readily available.. You could put some grease inside to help protect......... If your in no hurry to assemble, I would guess the seal is available.. I have never put in a new one.
Old Jul 25, 2019 | 09:13 PM
96f150's Avatar
96f150
Thanks Steve....Yeah I popped the cv joint back a bit and put some grease in there for now.....Keep on truckin!! 175k!
Don Bordeaux
1997 - 2003 F150
Jun 27, 2018 08:25 AM
thedaddycat
Dec 2, 2007 01:12 AM
90xlt4x4
Jul 21, 2005 11:50 AM
