Sponsored by: Auxito
Front wheel seal
Old Jun 4, 2018 | 10:01 PM
Don Bordeaux's Avatar
Don Bordeaux
Front wheel seal
I haven't had the "privilege" of working on the front end of my truck other than brakes, and just recently, ball joints and upper control arms. All of which was easy enough. And now a situation has come up that I'm not sure how to handle. I think that while changing the control arm on the driver's side, the wheel seal got damaged and is now leaking grease. I have tried to price a new seal only to be told that I would not be able to buy just a seal, and would have to buy a new hub assembly. Cost....$120. at O'Reilly's, and $54 from Amazon with free shipping. Didn't see seals though. Are seals available for a 2000 F-150 4x4? I would hate to spend $50-$120 for a complete hub if I can just buy a $10± seal.
Old Jun 5, 2018 | 10:29 AM
pdqford's Avatar
pdqford
IIRC, I got mine from the Ford dealer.
Old Jun 25, 2018 | 12:45 PM
FordRidingHigh's Avatar
FordRidingHigh
Is this the hub assembly for this vehicle? Looks like it's $92, but I can't tell which is the bad part. Is it part #4 in that illustration?
Old Jun 27, 2018 | 05:14 AM
96f150's Avatar
96f150
are you sure its leaking grease from the wheel seal? These are sealed hub assembllys and while its possble, its not likely leaking grease from there. Sure its not a minor hole in the outer cv joint boot. The rotational mass of that joint will throw grease all over
Old Jun 27, 2018 | 08:25 AM
FordRidingHigh
Yeah, when I've had seen leaks in the boots, usually it's easier to buy a refurbished axle and just swap the entire thing out and return the core.
sarnott140
Mar 30, 2012 10:15 PM
burning coal
Sep 10, 2011 04:34 PM
RhinoScores
1978 - 1996 Big Bronco
Sep 8, 2006 08:17 PM
wtroger
Sep 8, 2001 01:11 PM
