Outer hub seal?
Old Jul 21, 2005 | 10:35 AM
90xlt4x4's Avatar
90xlt4x4
Outer hub seal?
Well I had the f150 out on the highway last night and noticed grease spots on the rim after I got home, so I assume the hub seal is leaking. What is the name of that o ring that goes around the hub assembly, and where can I find one?
Old Jul 21, 2005 | 11:50 AM
andym's Avatar
andym
There's no outer seal. If it's leaking grease, it could either be the inner seal or someone put too much grease inside the hub. The inner seal isn't so much to keep grease in, it's to keep dust out. Very little grease is needed to lube the bearings and the lockout.
