Turning noise but not engine
What you could also try is turning the engine by hand and then try to start it again. If it starts, this is not a good sign. you might have a bad place on the flywheel or flexplate.
Also jot sure if this is helpful info or not but recently from a cold start the engine would turn much longer than normal before it would start. To the point was worried the battery would die. But once it ran for awhile if I turned it off it would start right back up after that if it was still warm. Hoping it’s just the starter.
Edit:
Not exactly what you have, but worth a read:
https://www.ford-trucks.com/forums/1...nsmission.html
Otherwise, if the belts just slip (even when you pinch to tighten them more on the pulleys) you can put a wrench on the crankshaft bolt inside the pulley/damper. Usually a 1/2" drive ratchet with the proper socket will do the job.
The issue is clearance and access, what with pulleys, fans, accessories, radiators and whatnot in the way. But sometimes it's actually fairly easy. Check yours out to see if it can be turned that way.
Does the same thing to an old tired, or more often new and cheap imported, starter relay on the fender.
So while a normal good starter and relay can take an awful lot of cranking without complaint, an old tired one might not. If I'm not mistaken, the lower the battery voltage gets, the higher the actual amperage the load sees for the same amount of work. Meaning even more heat as the battery starts to wane.
Can't tell from here if that's what happened in your case, but it's good info and worth keeping in the back of everyone's mind.
Once it was warm it was easier to start naturally anyway. But things may just be getting old, and the starter is a good suspect.
What about your battery and starter cables? Are they original? Might be something else to look into, but I think you're on the right track with the starter.
Crossing fingers anyway. Turning the motor over by hand to put it in a different spot on the ring gear might help if that's the issue, but not for long if the starter is the culprit.
Paul
