Sponsored by: Kumho
Axle pivot bushing replacement
Old Oct 6, 2003 | 09:57 AM
wbtguy's Avatar
wbtguy
Hey everyone, I am going to be replacing my front axle pivot bushings (TTB) this weekend, they are toast...alot of movement, i suspect that they are a major reason for some of my steering and alignment problems (i.e. truck will pull hard one way sometimes or ride perfect others). Anyhow, any one have any tips on doing this? I have heard that it is kinda a bitch to do, i dont have the poly ones, i have a stock rubber set. Not sure what its going to be like, so, if ya got any tips or ideas, i would appreciate them. Thanks.
Eric
Old Oct 7, 2003 | 10:33 AM
daveo916's Avatar
daveo916
They are kind of a bitch,(mostly the work taking the axles themselves out) not sure what yr. or model you have, I burn the old rubber out with an oxy-acetylene then use an air chisel to press out the metal part (a press will work too) mines a 2WD 75 250 w/79 I-beams and brakes, with the oval self-centering bushings
84-6.9L
May 13, 2011 11:50 AM
alchemist1
May 28, 2010 10:33 PM
BuddyFord
Sep 26, 2006 07:21 PM
slifer
Aug 31, 2003 01:49 PM
