Blown head gasket?
Old Jul 23, 2019 | 07:58 AM
Skagewa's Avatar
Skagewa
Blown head gasket?
Alright guys, once again I come to you to help a man and his truck out. I'm gonna make it short and try not to bore you guys.
Truck spews white smoke mid shift, feels like it's skipping every now and then while idling and driving.
Smoke doesn't smell sweet but I don't really have a good nose anyways. I checked the radiator and it's green. I checked my dipstick and my oil is just fine. I did have use 10w40 instead of 15w40 because nobody had it but I doubt that would cause the issue.
I'm hoping it's not a blown head gasket and I thought I'd go to the forums before I get a full diagnostic on it since the shops near me are kinda far away.
Thanks again guys
Old Jul 23, 2019 | 08:38 AM
hairyboxnoogle's Avatar
hairyboxnoogle
"mid shift" so when you let off the throttle? Bad fuel or failing IP
Old Jul 23, 2019 | 08:48 AM
Skagewa's Avatar
Skagewa
I did a little bit more research and I'm starting to agree with you thank the gods. I did fuel up at a different place so I might just have to floor tf out of it. Is changing the injectors hard? It doesn't seem too bad from the tutorials I been watching but I'm no mechanic.
Old Jul 23, 2019 | 02:23 PM
genscripter's Avatar
genscripter
Changing out injectors is not a hard job, just get a 1" wrench and turn them out. Be very careful not to ding up your valve cover.
While you are at it, you should change out the injector return caps and o-rings. https://www.rockauto.com/en/catalog/...ation+kit,6010 They tend to not survive the transfer. They like to remain undisturbed.
Old Jul 23, 2019 | 05:52 PM
Charmalu's Avatar
Charmalu
I use a 1" deep socket and a long Breaker bar. Doesn`t come close to dinging the VC.
Go onto www.McMasterCarr.com and buy a bag of 50 of the Viton O Rings, size 111.
Ther are around $7 + - and shipping. Good to have them on hand. for those OH Shucks
moments when one starts to leak.
111 7/16 ID x 5/8 OD part # 9464K24
Be sure to dig out the old Copper washers under the Injectors, and replace with new one`s.
Cgarlie
Old Jul 23, 2019 | 08:14 PM
Skagewa's Avatar
Skagewa
After a nap, and some reading, I think it might be because I mixed oil? I'm gonna replace the plugs when I have some money to do it because I'm in the middle of a move this weekend. Having an old truck is so frustrating but I'm not gonna give up on her.
Old Jul 23, 2019 | 08:15 PM
Skagewa's Avatar
Skagewa
From all the videos I've seen regarding blue smoke the blue smoke doesn't really look that blue. Sweet scent doesn't make sense because it just smells like unburnt diesel. And I wrong about this?
Old Jul 23, 2019 | 09:36 PM
hairyboxnoogle
If it just started out of the blue, either the internal bit that changes advance is stuck, or you got bad fuel. Dump a quart of atf in each tank and move on.
Old Jul 24, 2019 | 05:37 AM
DarkOverCast's Avatar
DarkOverCast
Drive it like you stole it afterwards, if it clears up but then comes back after driving it easy it's probably injector/injection pump related. Assuming your motor has good enough compression, which if it runs fine it probably does.
Old Jul 24, 2019 | 07:04 AM
Olds64's Avatar
Olds64
x2
As the others said it sounds more fuel related. Keep an eye on your oil and make sure you get fuel at a high volume station.
Prondo
Jan 4, 2013 04:24 PM
sbxworship
May 3, 2010 05:18 AM
usmc50bmgsniper92
Apr 27, 2009 08:57 PM
ccg711
22
Sep 10, 2006 11:42 PM
50jd60
Jan 28, 2005 04:21 PM
