6 Volt Generator for 292
Old Jul 22, 2019 | 10:57 PM
DDeffes's Avatar
DDeffes
Hey guys. I was wondering if there are new or rebuilt 6 volt generators available that will work in a 292? My 53 has a 292 in it and is going to be all 6 volt positive ground. I already have a new generator voltage regulator and wiring for a generator so I wanted to see if there was a generator option instead is switching to a alternator. Thanks
Old Jul 22, 2019 | 11:20 PM
Mixer man's Avatar
Mixer man
I believe a '54 generator will work for you.
https://www.macsautoparts.com/ford_t...-mount-v8.html
Old Jul 23, 2019 | 12:37 AM
Tedster9's Avatar
Tedster9
Yikes! That's not a generator, that's a small, el-cheapo alternator stuffed in a case, designed to look like a generator. $500 (+ shipping, and whatever your governor's cut). I doubt they are positive ground? I didn't check.
Were it me, I'd find a good used 6 volt generator off that auction site or a junkyard. They are cheap, because the demand for 6 volt units is about nonexistent. Shipping might be kind of high. Then rebuild it yourself, it's pretty simple. Bearings and brushes, basically. Maybe someone here at FTE has one they'd let you have at a decent cost. Not too many die-hard 6 volt enthusiasts out there left. Be sure to use nothing less than 00 ("double ought") battery and ground cables for everything.
Old Jul 23, 2019 | 12:45 AM
Mixer man's Avatar
Mixer man
Were it me, I'd find a good used 6 volt generator off that auction site or a junkyard. They are cheap, because the demand for 6 volt units is about nonexistent. Shipping might be kind of high. Then rebuild it yourself, it's pretty simple. Bearings and brushes, basically. Maybe someone here at FTE has one they'd let you have at a decent cost. Not too many die-hard 6 voltefs out there left. Be sure to use 00 ("double ought") cables for everything.
Yikes! That's not the one I thought. This is the one I meant.
https://www.macsautoparts.com/ford_t...B&gclsrc=aw.ds
Old Jul 23, 2019 | 12:51 AM
Tedster9's Avatar
Tedster9
That's better, though they still want $229 + $200 core. He doesn't have a core.
Old Jul 23, 2019 | 02:02 AM
Mixer man's Avatar
Mixer man
That could be a problem unless he could find one in an old wrecking yard. Maybe C/L or Vintage Truck Market.
https://www.facebook.com/groups/1608008129278375/
Old Jul 23, 2019 | 07:23 AM
Indybeer's Avatar
Indybeer
Is the generator for a 292 different than the 223? I converted mine to 12V and have the generator in a box somewhere.
Old Jul 23, 2019 | 08:16 AM
bigwin56f100's Avatar
bigwin56f100
They are the same
Old Jul 23, 2019 | 10:57 AM
Mixer man's Avatar
Mixer man
Originally Posted by bigwin56f100
They are the same
I thought the OHV engine generators had mounting ears on the end frames, and the flatties used the strap-on bracket. No?
Old Jul 23, 2019 | 11:22 AM
bigwin56f100
We aren't talking flattie. 223 6 cyl gen is the same as a y block 272 292 etc
Old Jul 23, 2019 | 11:30 AM
DDeffes's Avatar
DDeffes
Thanks everyone. I found one out of a 1955 292 Mercury with all the bracketry which I needed as well for $50. It seems like that should get me going. Thanks again!
Old Jul 23, 2019 | 12:00 PM
Indybeer's Avatar
Indybeer
Everything I can find online shows them as being the same. I will try and find the one I have and get a pic of it.
capelo
Jun 23, 2014 03:49 PM
MN1967
16
Jun 7, 2013 07:45 AM
OverReved
Electrical Systems/Wiring
Oct 16, 2011 01:37 PM
Sarge261
Jun 29, 2009 09:08 AM
60RatRod
May 15, 2008 05:07 AM
