Sponsored by: Real Truck
Map update
Old Jul 22, 2019 | 08:09 AM
Tom Compton's Avatar
Tom Compton
Map update
I can’t see $150 to up date the map on my 2012 F250. Lots for sale on the net but which one for this application?
Old Jul 22, 2019 | 08:38 AM
seville009's Avatar
seville009
I updated the map in my 2011 F350 for the first time about two years ago because I started traveling on a regular basis thru NYC and, in one area, the exit numbers had changed. New map still had the old exit numbers though; no other noticeable changes so it wasn’t worth the money.
New map came on a cd for my truck
Old Jul 22, 2019 | 08:39 AM
Just Strokin's Avatar
Just Strokin
You need a DVD to update the maps on the 2011 and 2012 trucks. SD cards are used on 2013-2016 trucks. Someone back 3-4-5 months ago suppose to have bought a DVD off eBay for a reasonable amount but not sure if it worked or not. You might search the forum.
Old Jul 22, 2019 | 08:50 AM
Tom Compton
Thx. Yea, I couldn’t see doing updates every year but after 7 years there are new roads and construction changes all over. Pulling a 30’ travel trlr makes missing or wrong turns a real pain especially at night. Last night it had me exit a couple of miles too soon then right back on the interstate. 7 years ago that was a construction bypass.
Found mention of an A10 card just want to know if that’s the one or do I need something different.
Old Jul 22, 2019 | 11:32 AM
Just Strokin
If you do not have the Sony radio with NAV, you will need a DVD. The A10 SD card will NOT work for you.
https://ford.navigation.com/product-..._US/FordNA/USD
Old Jul 22, 2019 | 11:42 AM
saratoga2011's Avatar
saratoga2011
The references you see to A10 are for the SD card based Sync 2 trucks (2013-2016) as mentioned.
The Sync 1 Denso nav system in your truck stores the map data on an internal hard drive and needs to be updated via a DVD.
Old Jul 23, 2019 | 12:55 PM
Tom Compton
Thx to all.
A DVD it’ll be.
tracyclifton
6.7L Power Stroke Diesel
May 23, 2018 07:01 AM
Jesse4812
Nov 10, 2017 04:35 AM
Readgriff
Oct 16, 2017 04:34 PM
Fert
Sep 24, 2017 05:57 PM
79F150400M
Washington Chapter
23
Jul 3, 2012 09:56 AM
