Fuel Filter Question
Old Jul 20, 2019 | 02:47 PM
MoreFoam's Avatar
MoreFoam
Hello,
I recently bought a 1993 Ford F-250 7.3L Diesel truck. I have never owned a truck before, much less a diesel truck. I am also not a mechanic, but I've done small tasks before, such as changing oil, rotors, brake pads, calipers, and once helping change a head gasket.
The truck is not in very good condition so I need to start learning to fix things. My first step is to change the fuel filter. The bottom of the fuel filter has a valve. I can twist this valve clockwise to expose the threading. Twisting counter clockwise makes screws it into the filter. I assume this valve is used to drain something. Here is my question:
Which direction opens the valve and which direction closes the valve? It is unclear to me and I don't want to put water in it to find out, because I'm not sure if that could damage the filter. I am assuming I want the valve closed when installing.
Any other advice is appreciated. Thanks in advance.
Old Jul 20, 2019 | 03:24 PM
MoreFoam's Avatar
MoreFoam
Here is a link to the fuel filter I have:
https://www.autozone.com/filters-and...99_303698_4191
Old Jul 20, 2019 | 08:51 PM
Charmalu's Avatar
Charmalu
You won`t damage the filter. The valve is there to drain off any accumulated water.
The last filter I would ever use is a Fram. They are junk. you are better with a Wix or Motor Craft.
here is a list off rock Auto. I would buy local as RA has shipping charges.
https://www.rockauto.com/en/catalog/...el+filter,6200
I don`t have your year truck, so not sure which filter to use. Our local O`Reillys sells Wix and Motor Craft.
Charlie
Old Jul 21, 2019 | 12:27 AM
DarkOverCast's Avatar
DarkOverCast
I've read online about the frams having a bad rep and what not yet every one I disassembled showed no signs of failure. I know several people that run fram oil filters religiously yet still get 300+k out of there motors (gas motors)
Whatever the factory did, which just about every market is supposed to match is good enough for these old mechanical rigs. The better filters just clog sooner in my opinion, over a long period of time it probably does help. But short term I think the effects are nil.
Idi's mostly run a max injection pressure of 2,000psi and the holes in the injectors are HUGE compared to the modern stuff.
I run the wix/motorcraft just whatever the local place has on hand, but every now and then I end up with a cheapo such as a micro guard (made by wix) but I can't see why running the Fram for now would be a bad idea. If your want something more reputable just go with it next time.
I change filters once a year. Roughly 10-15k on them.
Most water separators I've seen out is to seal and in is to drain. If the drain is open it'll just leak diesel. And you'll figure out which way is which. The water is heavier than diesel so it just naturally sinks to the bottom and once the water is drained out diesel will follow it.
A new filter is better than no filter or a clogged one.
Old Jul 21, 2019 | 08:33 AM
RaymondIV's Avatar
RaymondIV
Whenever anyone asks this question they get totally confused by the correct answer because the valve is upside down. I'll just say the valve is normal right hand thread. Think of it as if you were under the truck looking up at the valve, you would turn the **** to the right to close it.
Old Oct 16, 2019 | 09:42 PM
Onemoreblessedtexan's Avatar
Onemoreblessedtexan
I can't seem to locate a fuel filter with a water separator for a 6.9L 86'. If anyone knows and will post a part # it's greatly appreciated!
Old Oct 16, 2019 | 10:07 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I think you will have to change the Filter Base ... like the Napa 3123 and the Base I think is 4309.... but ask Napa for the Match.... your truck had a separate Water separator from the filter and Most folks just change the Base to use a combined Filter/separator.
Personally, I would go looking in the JunQue Yard for a 7.3 filter base
IF you buy the 6.9/7.3 housing that will cost ya like 70 bux and you will have to buy the heater to Plug the hole for another 70 bux .
Old Oct 17, 2019 | 07:25 AM
RaymondIV's Avatar
RaymondIV
The 6.9's had a different original factory filter system. They had a water separator remotely mounted and not part of the filter like a 7.3.
Old Oct 17, 2019 | 10:29 AM
Onemoreblessedtexan
Thanks Fellers! I'll be looking into Your suggestions. I'm about to dive real deep into this 86' so I'll be in the forums daily. I'll make sure to dig through the threads of the past to source as much info as needed so to not hijack threads and create unnecessary threads. Thanks!
mikeboggess
13
Oct 17, 2015 07:04 AM
Ziggy81
Nov 20, 2013 06:41 PM
57trailer
Aug 3, 2008 12:14 AM
propaneman
Jun 14, 2008 03:43 PM
spitball
Dec 29, 2003 10:25 AM
