Question #212. 91 F250 7.3 diesel I.D.I.
Fuel/water separator. I am replacing this filter about every 2 months. Is that unusual? I am using MicroGuard filters (because of cost) and was wondering if I should change brands. Curiously I performed an autopsy on the last filter and could see no obvious contamination. Opening the water drain valve seems to release only fuel. This truck sat for 2 years, when I first got it running I was able to see water when I opened the drain valve, however that stopped after a while. I did use some Seafoam early on to dissipate the water problem.
Received 3,108 Likes
on
on
the fuel filter change interval is every 60k miles or 4 years,whichever occurs first.
(they're massive,at the size of a common oil filter.)
drain your water trap every 5k miles (sooner if you get the water in fuel light.)
i use racor filters.
(great micron ratings.)
I use two different fuel providers, but one of them 80% of the time. It is curious to me that I am having to change this filter every 2-3 months though. I am changing the filter this time with a Motorcraft brand to see if it helps. It is again curious when I cut a previously used filter in half that I saw no visible contamination. I am going to drop the tanks and look for debris as this truck sat for 2 years before I repurchased it from a family friend. After I got it running I did notice water present when I opened the valve under the filter but have not seen water in the last 8-10 months. Thank you for your reply.
Truck turns over more than usual, usual is within a 2 sec. duration (even during cold weather) and runs rough, but not as rough as it is running now and sometimes the truck will not restart after it is shut off, if I wait 10-15 mins. it will restart. The Microguard filters may be the problem, I was using Wix brand and getting more usage (4-5 months). I have just purchased a Motorcraft filter but have not installed it yet.
THIS JUST IN!OK, changed the fuel filter with a Motorcraft instead of the Microguard, truck started and ran smoother than it ever has . . . . . then it died. I think once it consumed the fuel in the new filter it starved out and now will not restart. I t is getting no fuel . . . . so it must have a bad fuel pump, am going to replace it with an electric one and be rid of the mechanical one.
on
yeah,you can stop replacing the fuel filters.those are not the issue.
to test the lift pump,you need to try and run the engine from a jug of diesel.if it runs smooth,than you'll know it's fine and that she's sucking air from the line someplace going to the pump.
if you place a electric fuel pump before the air leak,if you have one.then you'll just have the same problem because electric or mechanical,it's still got to suck from the tank without air holes.
Ziggy81
11-20-2013 06:41 PM
90pioneer
11-03-2013 08:23 PM
propaneman
06-14-2008 03:43 PM
