A/C Issues
Old Jul 21, 2019 | 06:08 AM
PSU4ME's Avatar
PSU4ME
Are you putting any oil in with it when you add refrigerant?
Old Jul 21, 2019 | 10:15 AM
Kschab123's Avatar
Kschab123
I put oil in the compressor before i installed it.
Old Jul 21, 2019 | 04:57 PM
Hit Man X's Avatar
Hit Man X
System holds 38oz.
Oil charge should be around 8oz. New comps are usually prefilled. Did you flush the line set? Evap? Condenser? You may be over oiled.
What gauges are you using?
Old Jul 21, 2019 | 08:20 PM
Kschab123's Avatar
Kschab123
The comp i bought had 3oz in it. I poured it out and added 7 oz. I put the whole system under vacuum for about 45 minutes before trying to charge it. I have those harbor freight guages.
Old Jul 21, 2019 | 08:23 PM
Hit Man X's Avatar
Hit Man X
They are so so. See if you can return. Cough up another $40-60 for Mastercool or Yellow Jackets.
Did you buy the vac pump? Rentals have oil never changed...and it needs to be done due to moisture.
Where are you located? I will help if in Texas or Louisiana.
My truck averages mid 40s from the vents on max AC in upper 90s without tint.
Old Jul 22, 2019 | 08:48 AM
Kschab123's Avatar
Kschab123
I bought the vacuum pump. Yeah might be worth getting new guages. As its leaking somewhere. Either in the system or guages. Im thinking of maybe using one of those cans of r134a with the hose and guage atached to see if the system will take it which will tell me if its the system that is leaking as i wouldnt be using the guages. The oil i put in the compressor had uv dye and i checked the system with uv light to check for leaks but didnt notice anything. But should the system be under pressure to check for leaks?
Old Jul 22, 2019 | 09:53 AM
Kschab123's Avatar
Kschab123
Curious also if puting oil in the compressor then putting it under vacuum would have sucked it out?
Old Jul 23, 2019 | 01:51 PM
PSU4ME's Avatar
PSU4ME
All you need is for it to leak out and you should see it with the UV light. I'm assuming you charging it was enough pressure to push it out.
lasitter
May 14, 2010 06:55 AM
Gr8ride
Jan 4, 2006 05:02 PM
rdboykin
Jul 21, 2004 07:56 PM
sail2244
Aug 30, 2003 09:21 PM
