E4OD forward ring gear question
Old Nov 8, 2019 | 07:10 PM
nateairman's Avatar
nateairman
Now you are set up for 4x4! Put a transfer case in and a rear drive shaft out of a 4x4. Good to go!
Old Nov 8, 2019 | 08:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by KingDeleted
Will this be possible?
Yes, it is possible, if that truck had the same engine as your truck.
Old Nov 16, 2019 | 04:17 PM
KingDeleted's Avatar
KingDeleted
got the new one torn down to extract the hard parts that I need. Question. Why is the shaft a different length going into the transmission? I expected the part past the parking pawl to be longer but not the other side. The plan going forward is to use the best of the parts and put it all together with the original case. Any info is helpful
edit: I’ve realized my error lmao
Old Nov 16, 2019 | 04:34 PM
00t444e's Avatar
00t444e
The shafts are the same length going into the transmission you have the bottom one turned around. Top is for a 2wd van and bottom is for a 4x4 truck.
Old Nov 17, 2019 | 07:05 AM
KingDeleted
you may be 100% right but in my case, both transmissions are 2wd, the bottom one came out of a 450 with the driveshaft brake. Did ford simply use a 4wd transmission and engineer a different tailhousing for the bigger trucks? I really don’t know.
Old Nov 17, 2019 | 09:49 AM
farmert's Avatar
farmert
The 450s used the 4X4 transmission with the brake mounted to the tail shaft for the 2 wheel drive trucks. Ford didn't make a 450 4WD version.
Old Nov 18, 2019 | 06:00 PM
KingDeleted
Thanks to all those pitching in and helping me. I’m in the process of assembling the transmission, up to the part where you compress the intermediate clutch spring to get the snap ring over the piston. Before I proceed any further I have a snap ring that is bugging me out. It’s about the size of the intermediate clutch and smaller than the ring used to retain the overdrive clutch piston. In other words the ring is smaller than the part I’m up to. It measures just under 9’’... ummm where does this snap ring go?
Old Nov 26, 2019 | 02:10 PM
KingDeleted
Update:
I still can’t figure out where the snap ring goes. Going to assemble the “bad” transmission as a core and see if I can’t find a spot for this mystery 9” snap ring
Old Nov 26, 2019 | 02:14 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
If the transmission has already been rebuilt, it's possible that the center support has been machined due to wear. In that case, the snap ring will go in before the center support.
https://www.sonnax.com/parts/2080-center-support-ring
Old Nov 27, 2019 | 09:18 AM
KingDeleted
You are correct Cleatus, Thankyou. The snap ring ( .050”) came from the donor transmission and is not needed for the original case. Mystery solved
Old Nov 27, 2019 | 09:48 AM
nateairman's Avatar
nateairman
Why don't you use the center support from the donor with the snap ring as it is a wear prevention item.
Old Nov 27, 2019 | 11:30 AM
KingDeleted
I don’t have an answer for that. I’m going to end up tearing down everything again and reassembling everything anyway to double check before she goes in the truck. At that point I will measure both center supports and see if there is a difference
Old Nov 27, 2019 | 08:24 PM
  #28
trackspeeder's Avatar
trackspeeder
Use the center support that has been machined for the support ring.. The machined center will not have any lugs. When you install this ring, the gap is to the bottom of the case.
Old Dec 14, 2019 | 12:24 AM
  #29
KingDeleted
I measured the center supports and again, Cleatus was right. The machined one was roughly 1/16 inch thinner so I used the snap ring to fill up the gap. What do you mean the machined one will not have any lugs?
also I’m installing the pump and it’s being a real PITA. Manual states to use “hand power” to seat the oil pump but I cannot get it to seal in and sit flush after trying several times with transmission fluid as a lubricant. Any suggestions?
Old Dec 14, 2019 | 07:54 AM
  #30
cleatus12r's Avatar
cleatus12r
Butt-Head
Did you disassemble the pump?
Those things can't just be bolted together "close enough". If it's bolted together off-center enough you'll never get it in without brute force and when you do, there go the bushings in the center bore and it will leak when installed and ran. There are tools (commercially available or home-made) to do this.
If you never took the pump apart or used a tool to align the pump halves, you have a stack problem and something is not installed all the way, bottoming out the pump before it's seated in the case. The coast clutch is the hard one if it's not pre-assembled with the overdrive gear assembly. I've never used the tool as it just takes patience putting in the coast clutch drum BEFORE the overdrive clutch plates (reverse of the manual instructions). It really can't be a stack problem aft of the center support or you'd never get that in.
