Sponsored by: Real Truck
Engine code problems
Old Jul 19, 2019 | 04:30 PM
MEVANS52's Avatar
MEVANS52
Exclamation Engine code problems
I drive a 2015 F250, diesel 6.7, 38k miles.
last week driving down the road, lost power, the low oil, Advance Trac, Engine over heating and the wrench codes appeared on screen. I pulled over to side, stoped put truck in park and tried to start after checking oil, temp etc. when I attempted to start nothing happened, did not turn over no clicking ( like a dead battery sound) but the radio, instrument panel flashers all worked with no problem. Called dealer and was towed. Monday the service tech went out and truck started. The codes appeared, Ford’s service manual said to clear codes then test drive and watch for first code,. Problem is no codes and after fifty plus miles of road testing still no new codes.
any thoughts or ideas?
Old Jul 19, 2019 | 04:55 PM
seville009's Avatar
seville009
I’d ask them what the old codes were that they cleared.
Old Jul 19, 2019 | 05:45 PM
scottscott's Avatar
scottscott
There is a connection in the wiring harness above the parking brake. This connection comes loose, & causes the problem you describe. Cure is to work the connection in & out a few times, & remove the attachment of the harness to the parking brake assembly. Wire tie it up & out of the way. Doing this cures a lot of the trucks that have this problem. It worked on the 2013 I drive that started doing this a few years back, & the problem hasn't come back.There are some detailed threads on this site about this problem, you may find them with a search.
Old Jul 20, 2019 | 07:59 AM
MEVANS52's Avatar
MEVANS52
Thanks for your info.
Under what topic do you suggest I search related to finding the threads?
Old Jul 20, 2019 | 03:21 PM
scottscott's Avatar
scottscott
Do a search for "service advancetrac".
Here's one thread: https://www.ford-trucks.com/forums/1...e-on-dash.html
Old Jul 26, 2020 | 12:58 PM
Alloy's Avatar
Alloy
Moved to: Error Messages: Service AdvanceTrack/ Hill Descent Control Fault
rriveroll
Sep 26, 2019 06:55 AM
cay5628
6.7L Power Stroke Diesel
21
Jun 17, 2017 01:32 PM
JonArmy
Dec 10, 2013 12:45 PM
barrynelson
Aug 26, 2005 07:34 PM
myvan
Aerostar
Jul 13, 2003 07:35 PM
