Service Advancetrac
Service Advancetrac
I am getting the SERVICE ADVANCE TRAC message on startup and the ABS and TRACTION CONTROL lights are on.
Happened after hitting a pothole at high speed on 4x4 on a dirt road.
Strange thing is im getting no DTC Codes and wont reset. Im using both a basic 30$ OBD scanner and also with a 5 Star Tunner.
Any ideas why I dont get the codes, and also where should I start troubleshooting?
2013 F250 Superduty 6.2L Lariat Crew Cab
Should I get the bluetooth version or the wi-fi version. I guess it depends on FORScan, I would prefer using my android phone (Bluetooth) unless the Windows version (Wi-Fi) is better. What do you think?
Inside the cab, right above the parking brake pedal. There should be a harness clipped to the parking brake assembly, & a couple of plugs near by. Wiggle those plugs & work them back & forth, then push in tight. Some remove the harness from the brake assembly & wire tie it off to something else. I got by with just wiggling the plugs.
On a related note... a $2000.00 scanner at a shop couldn't pull the codes and make changes to the modules like FORScan could.
Between free FORScan and 75.00 for the OBDLink its a no brainer for any Ford owner with some basic garage mechanic skills.
What ever side you hit the pot hole with I’d check your abs wire/cable on, sounds like it either be torn or cut.
As for obd, I tried the WiFi for iOS, the MX with Android is where I landed. It just works better for me. Went through red WiFi versions with intermittent connectivity before making the call. Then I got the response of “good call the MX works better” great customer service though. Used phone from pool of friends, easy to come across cheap if not free on a bet.
I would get maybe 5 min at max, where on the MX it works the duration of the trips no issue. Highly recommend moving over to the MX if you are looking for continual monitoring.
yes, because its all about CAN Bus... when they moved to CAN bus in 2005/2006, that's when they started introducing multiple controllers or modules that all essentially talk to each other over the Controller Area Network (CAN). That's why most of these off the shelf scanners are for ****, because they don't know how to interpret the CAN bus messages coming from the other modules. (at least that's my hunch). They are only aware of the PCM and TCM... now you have body control module, brake control module, steering control module, infotainment control module.... etc
Its honestly gotten ridiculous... and Ford thought they would be cute and create proprietary tools like their IDS tool that is the ONLY thing that can talk to it... Thank GOD for FORScan...
