Modular V10 (6.8l)
Fuel gauge issue
Old Jul 18, 2019 | 09:24 PM
kemsley21's Avatar
kemsley21
Fuel gauge issue
I have an early build 99 v10. I just replaced my fuel pump and assembly (installed a motocraft) my fuel gauge is reading empty now. It should be around half a tank. I drove it around the block a few times and the needle moved to about an 1/8th. Any ideas? Is it something that needs run time to calculate?
Old Jul 19, 2019 | 10:08 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Nope, has to be something either wrong with the float sensor/wiring, or it's the wrong sensor. Do you still have the old fuel pump? You might be able to swap it.
Old Jul 19, 2019 | 12:28 PM
kemsley21's Avatar
kemsley21
I didnt get rid of anything yet. I'm wondering if I ordered the wrong one. There's too many to choose. I'm starting to think there wasn't anything wrong with my old one
Old Jul 19, 2019 | 12:51 PM
krewat's Avatar
krewat
Why did you change it out in the first place?
Old Jul 19, 2019 | 12:58 PM
kemsley21's Avatar
kemsley21
Since I've owned it, it's always kinda stumbled into a start up after sitting for awhile. Had my headgasket go out at 173k so I decided to just throw in a remaned engine. Start up symptoms didnt go away. I had my gf take it to work (works at ford) the guys there said my fuel pressure was bleeding off and that's what was causing the start up issue. About a week after that it started having a misfire. Threw a code for random misfire and cylinder 10 misfire. I thought it had to be cause by the bad/leaking pump.
This morning when I started it up, it still stumbled
Old Jul 19, 2019 | 01:05 PM
krewat's Avatar
krewat
Did you change the fuel pressure regulator?
Old Jul 19, 2019 | 01:15 PM
kemsley21's Avatar
kemsley21
Yes. And pcv, IAC valve, cleaned the MAF, replaced numerous vacuum lines, fuel filter, brand new spark plugs. Only thing left are the coils. I was told they were replaced at 150k but he used accel, not motocraft
Old Jul 19, 2019 | 01:44 PM
krewat's Avatar
krewat
Weird. If you cycle the key a few times before starting, does the stumble go away?
Old Jul 19, 2019 | 02:08 PM
kemsley21's Avatar
kemsley21
I haven't tried that yet. I'll get back to you on that one tomorrow
Old Jul 19, 2019 | 07:29 PM
kemsley21's Avatar
kemsley21
Ok fuel gauge is working now. I filled up and it shows full. Truck is still running rough. Threw a code for p0153
Old Jul 25, 2019 | 01:55 PM
maticuno's Avatar
maticuno
To help reset the gauge, disconnect the battery for 30 seconds, then reconnect. I just had this issue with mine.
Old Jul 27, 2019 | 07:49 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Are you sure you don't have a intake manifold or gasket leak or any place after the maf? That will give you a lot of different problems depending on the temp of the motor with things expanding or contracting.
Denny
kemsley21
Jul 19, 2019 07:28 PM
caleballen95
1997 - 2003 F150
Jul 20, 2013 10:06 PM
sfc11b
Sep 16, 2012 12:14 AM
diesel7.3power
Aug 11, 2011 09:28 PM
Old & Crunchy
May 15, 2004 09:17 AM
