Sponsored by: Real Truck
Fuel gauge issue
Old Jul 18, 2019 | 10:20 PM
kemsley21's Avatar
kemsley21
Fuel gauge issue
I have an early build 99 v10. I just replaced my fuel pump and assembly (installed a motocraft) my fuel gauge is reading empty now. It should be around half a tank. I drove it around the block a few times and the needle moved to about an 1/8th. Any ideas? Is it something that needs run time to calculate?
Old Jul 19, 2019 | 10:43 AM
alloro's Avatar
alloro
Try disconnecting the battery for a few minutes to allow the system to reset. If that doesn't solve the issue then you might need a new sender.
Old Jul 19, 2019 | 12:30 PM
kemsley21's Avatar
kemsley21
I had the battery disconnected the entire time of replacing the it. I bought the whole assembly, so it came with a new sender and pump. Could I have bought the wrong one?
Old Jul 19, 2019 | 02:43 PM
Djosbun's Avatar
Djosbun
What was wrong with the old fuel pump? Same gas gauge issue? How’s the condition of the harness and connector?
— Dave
Old Jul 19, 2019 | 03:33 PM
kemsley21's Avatar
kemsley21
Since I've owned it, it's always kinda stumbled into a start up after sitting for awhile. Had my headgasket go out at 173k so I decided to just throw in a remaned engine. Start up symptoms didnt go away. I had my gf take it to work (works at ford) the guys there said my fuel pressure was bleeding off and that's what was causing the start up issue. About a week after that it started having a misfire. Threw a code for random misfire and cylinder 10 misfire. I thought it had to be caused by the bad/leaking pump.
This morning when I started it up, it still stumbled
Old Jul 19, 2019 | 07:28 PM
kemsley21's Avatar
kemsley21
Ok fuel gauge is working now. I filled up and it shows full. Truck is still running rough. Threw a code for p0153
kemsley21
Modular V10 (6.8l)
Jul 27, 2019 07:49 AM
TexasGuy001
Dec 31, 2018 08:41 PM
StangPullerF250
Oct 28, 2013 08:15 PM
Old & Crunchy
May 15, 2004 09:17 AM
