F1 lower splash pan
Old Jul 18, 2019 | 10:02 AM
moejr's Avatar
moejr
F1 lower splash pan
While going through some junk F1 parts I found the lower splash pan from my 49 that was never installed..... plan is to recondition and install it but not sure what's involved. Do I need to remove anything on the front grill / bottom valance to get this in place? Can you post a photo of how it fits?
Old Jul 18, 2019 | 04:25 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
From what I recall it's a pretty straightforward install. I don't think you have to remove anything, just slip it in place and run the bolts in. I think I have one of those laying around since I fabbed my own radiator mount. I drove around for years without one and in heavy traffic my engine would start to get a bit warm. Once I fabbed an upper and lower valance to direct all the air through the radiator I haven't had any over heating issues at all.
Bobby
Old Jul 18, 2019 | 09:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm curious why there are two holes in it? One for the draft tube, and one for the radiator drain? But the radiator drain is on the front side of my radiator.
Old Jul 18, 2019 | 11:10 PM
bobbytnm's Avatar
bobbytnm
Ross,
Believe it or not, I think that is the crank hole.
Bobby
Old Jul 19, 2019 | 07:11 AM
chriscris's Avatar
chriscris
Crank hole and rad drain. The seal goes toward the radiator and it bolts to the rear edge of the part below the grille and to the inner fenders.
It is on an angle when in place
Old Jul 19, 2019 | 03:41 PM
moejr's Avatar
moejr
I'll try sliding it into place from the top, might have to remove the horn for more room to work. Not sure why it has the crank hole .... is the other hole for clearing the drain petcock?
Old Jul 20, 2019 | 11:24 AM
ALBUQ F-1's Avatar
ALBUQ F-1
AFAIK, the splash pan is screwed to the lower lip of the front crossmember and to the frame rails on the side, it totally mounts from underneath. Or else I'm misunderstanding which piece this is?
here it is:
https://www.ford-trucks.com/forums/1...l#post16242688
Old Jul 21, 2019 | 08:17 PM
bobbytnm's Avatar
bobbytnm
Ross,
On the 48-50 trucks the lower valance bolts to the front clip, not to the frame. You can kind of see it in this pic
Here's a pic of the area with the lower filler removed. You can see where it bolts across the lower valance and up the inner fender panels.
I would think you could snake this piece up from the bottom and twist it into place and bolt it all together. There is just a rubber seal between it and the lower part of the radiator/radiator support. I'm not using the factory radiator mount in mine so the piece wouldn't fit.
Old Jul 21, 2019 | 09:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Gotcha! It looks a lot like the pan (that is usually long gone) that goes under the whole front of the engine, behind the radiator.
Old Jul 22, 2019 | 09:09 AM
moejr's Avatar
moejr
Never knew there was a pan that went under the front of the engine, checked the Web and found out it's called a Engine Splash Pan PT. #7RC-6775-A, will fit 48-52 F series trucks, learn more things everyday on FTE forum! Thanks for posting the photos.
Old Jul 22, 2019 | 09:00 PM
bobbytnm's Avatar
bobbytnm
No problem. I thought I had one of those exploded parts diagrams of the front clip but I haven't been able to find it.
I'll keep digging
Bobby
Old Jul 22, 2019 | 09:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Here it is
Old Jul 22, 2019 | 09:21 PM
bobbytnm's Avatar
bobbytnm
Ross,
Excellent!! that's the one I was looking for. Thanks
Here's a diagram of the rest of the front clip;
Gertie-The '49 F2
17
Jul 17, 2012 12:20 AM
bmarsh
Jul 4, 2012 10:25 AM
nicpapageorgio
Mar 31, 2009 10:33 PM
going slow
Feb 25, 2008 12:38 PM
51dueller
Jul 2, 2005 09:57 AM
