Pushrod/Tapit gallery cover question
Old Jul 16, 2019 | 07:33 PM
JamesJ4's Avatar
JamesJ4
So I just embarked on getting rid of some oil leaks and did my pushrod cover gasket last night....it was tedious but I did it in around 2 1/2 hours total (had wait time on the rtv to hold gasket in between also). Problem is I read a lot about this and after I got it set up I torqued it down to spec......except the spec I read online was listed as 20 FT-LB. Now I look at my chilton and it’s listed as 18 to 27 IN-LB. Jesus Christ what did I do?! I didn’t bend the cover from what I can tell and I don’t see any visible oil leaks from there that I can tell. My valve cover gasket leaks and it’s hard to say on the back end near the fire wall if that’s the Gasket I just did or my valve cover.
anyway is this the right torque? 18 to 27 in-lb or is it 20 ft-lb? And if it’s inch pound should I go loosen the bolts up? I hope I didn’t do all that work for nothing!
Old Jul 16, 2019 | 08:26 PM
stephandrusty's Avatar
stephandrusty
18 to 27 . Just past finger tight Inch lb.
Old Jul 16, 2019 | 10:34 PM
JamesJ4's Avatar
JamesJ4
Well I wonder if I should back them out then. I’m way over torque right now.
Old Jul 17, 2019 | 08:19 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Somebody school me, is this on our trucks? what year? what motor? pushrod cover gasket, and valve cover gasket? if you used the cork gasket, I would start over, because if you back off from 20 ft.lbs. to 18-27 in.lbs. I wouldn't take the chance of just backing off, or your leak/drip could become runs very quickly
Old Jul 17, 2019 | 03:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My assumption would be that he is working on the side cover on a 300. I agree that once you tighten the bolts you cannot loosen them (bolts) and then tighten at a lesser setting. The gasket has already been crushed and it will leak.
Old Jul 17, 2019 | 04:24 PM
torq'ta 5 8
Thanks My4Fordtrucks, I assumed also, but I didnt see motor working on...so I wanted to back up and punt
Old Jul 17, 2019 | 09:31 PM
JamesJ4's Avatar
JamesJ4
Sorry about that guys. It's a 1992 f150 4.9.
Todd Meinders
1997 - 2003 F150
Dec 16, 2017 02:38 PM
92f2507.3idi
Jul 21, 2017 10:53 PM
R1racer
13
Apr 16, 2015 12:31 AM
WilleyJoe.62
19
Mar 4, 2014 07:44 PM
norm805
Jan 21, 2007 12:17 PM
