Injector question
Old Jul 15, 2019 | 12:56 PM
mcali2's Avatar
mcali2
Injector question
I am going to do my injectors now. I am trying to figure out what is the best bang for my buck and power For now I have stock turbo and billet wheel from riffraff. I want to maximize power for my turbo, what injector size will do that? also thinking of future mods like better turbo. maybe a injector that will work but will still fill the need with an upgraded turbo.. In all I don't want to push it too much as a trans is not a upgrade I want to do before it is needed. I have e fuel and an intercooler, will also be putting on the water injection at the same time.
Old Jul 15, 2019 | 01:57 PM
knottyrope's Avatar
knottyrope
I would go stage ones unless you want more powah
500-1200 depending on your current injectors
1994.5-1997 AA/AO Single Shot injectors | Rosewood Diesel Shop of C******, OH
Old Jul 15, 2019 | 02:53 PM
nateairman's Avatar
nateairman
Even with stage ones you will be fighting egts. May as well ditch the stock turbo system asap then do injectors.
Old Jul 15, 2019 | 04:14 PM
mcali2's Avatar
mcali2
With what?
Old Jul 15, 2019 | 08:13 PM
nateairman's Avatar
nateairman
Originally Posted by mcali2
With what?
Mike. Prepare yourself. Decide what power you want then choose air then choose fuel. If you want a good towing rig look at when Glenn has built, which is what I have done to some extent
I am running a 366sxe from Irate with stage ones from Jim and an all aluminum IC. I have efuel and a t500 as well.
Granted I didn't buy the turbo first and spent a fair amount of time and money making bellowed up pipes and building a d66 with a billet wheel. If I had put the turbo in first I wouldn't have built the top side of my efuel twice nor would I have built up pipes and IC pipes.
I don't need to spend your money choose what works for you.
Old Jul 15, 2019 | 09:16 PM
oldbird1965's Avatar
oldbird1965
Nate is correct. With only stage I's you can melt down the motor. Controlling EGT's with the 366sxe really helps, its a great fast spooling turbo. I went with the adrenaline hpop but the T500 is very good also. I have really good power to a point of EGT's getting high. But I can use the power longer with this setup then any other setup that I've had!
Old Jul 16, 2019 | 10:01 AM
mcali2's Avatar
mcali2
OK i will get that turbo first. what else is needed for that turbo? different mounts and up pipes? I would be grateful for a parts list if you have one so i can just go buy it. Will i need a custom tune just for the turbo upgrade? The turbo may be all i need or is it not much without the injectors? Thank you. If I don't spent this money soon it will go to something like ammo for my 50 cal and i don't need that LOL
Old Jul 16, 2019 | 12:34 PM
nateairman's Avatar
nateairman
Mike get the full kit from Irate. Make sure you have efuel and be ready to do some mods to the fire wall.
Edit:
Irate366sxe
Give them a call as well. They are super helpful and will make sure you get what will work for you. I see they have 369 and a 372 now as well......
Old Jul 16, 2019 | 03:46 PM
mcali2's Avatar
mcali2
ok thanks that is what i was looking for.
Old Jul 17, 2019 | 01:42 PM
dclack's Avatar
dclack
That turbo will be useless without larger injectors. Personally, I'd get injectors first. In fact that is what I did. Yes, I see high EGTs with stage 1s and the stock turbo, but I can manage them very easily with the correct tune and my right foot. And towing it still way better than with stock injectors. Do I want a bigger turbo? Of course, who wouldn't. But I don't feel I absolutely need it. Just my $.02.
Old Jul 18, 2019 | 11:22 PM
Bob_T's Avatar
Bob_T
Before messing with injectors and turbo mods I'd get a PHP Hydra chip. There is a good selection of tunes that come along with it and that may be all you need.
Old Jul 19, 2019 | 10:19 AM
knottyrope's Avatar
knottyrope
OP has a chip already. DP TS type
cowmilker08
13
Aug 3, 2010 06:26 PM
Boss300
16
Dec 10, 2008 04:18 PM
my79f
Oct 23, 2007 07:06 PM
brickie
Sep 3, 2007 03:34 PM
mhalter
Jul 29, 2004 11:51 PM
