Snap Ring Pliers
Old Jul 14, 2019 | 10:54 AM
Hanger53's Avatar
Hanger53
Snap Ring Pliers
Anybody have a source for a snap ring pliers for a clip like this? Nothing in my tool box seems to work very good. Found one online for a $40 but seems a bit speedy for single use..
Got them out with a screw driver but re-installing is a challenge so far...
Old Jul 14, 2019 | 11:14 AM
schoo's Avatar
schoo
The green ones are SK
Red one only says made in USA
the red one is getting worn out fast
Old Jul 14, 2019 | 11:17 AM
ALBUQ F-1's Avatar
ALBUQ F-1
KD Tools #2534, made just for external snap rings, they have flat ends that catch the ends of the rings. Is that the output shaft snap ring on the 3-sp? If your ring looks like that, consider yourself blessed. Every one I've opened has the beveled ends cut the other way, making it impossible to grip anything.
edit: the red one above is the KD 2534 or a clone
Old Jul 14, 2019 | 11:18 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
I have one of these I bought probably 50 years ago. Works good. Stu
https://www.ebay.com/itm/CRAFTSMAN-V...QAAOSwtGdctlwx
Old Jul 14, 2019 | 11:22 AM
Mixer man's Avatar
Mixer man
For that type of snap ring you should use parallel opening pliers. Yes, a good pair will run around $40. Good luck.
Old Jul 14, 2019 | 10:09 PM
Oldb's Avatar
Oldb
If you know exactly which pair you need you might fine a good set on ebay. Sometimes you can get a smoking deal, but for a tool truck name brand you will still typically pay over 50% of new. At least that has been my experience.
B
Old Jul 14, 2019 | 10:32 PM
ford390gashog's Avatar
ford390gashog
I just checked my toolbox, I use the Wilde Tool G409P. They are under 25.00 online. Not a tool you find at a local tool store.
Old Jul 14, 2019 | 10:48 PM
Hanger53's Avatar
Hanger53
Thanks a bunch guys!!! I bought the KD Tools #2534 on Amazon for $16.23 free shipping. Be here Wednesday!!!
Old Jul 14, 2019 | 10:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I couldn't find this earlier. This is a drawing I made of the snap ring that was on my output shaft. I ended up cutting it with a Dremel, what else can you do ??!!? Nothing would grab it.
Old Jul 15, 2019 | 07:19 AM
Doc's Avatar
Doc
I had to flag down the MAC Tools truck to get mine. $$ They're called "hog ring" snap ring pliers (or at least that's what I've been told.
RojoStar
Aerostar
20
Mar 29, 2022 02:03 AM
silverbullet6oh
Mar 13, 2017 10:00 AM
William Mark Brown
Oct 7, 2015 04:27 PM
madclone
Bronco II
Feb 25, 2008 01:39 PM
dyarumian
1978 - 1996 Big Bronco
18
Dec 11, 2003 06:17 PM
