Bronco II Ford Bronco II
help! how to disconnect a quick +
Old Feb 24, 2008 | 01:11 PM
madclone's Avatar
madclone
disconnect? )
Guys, help. Need to disconnect clutch hydro line to take off the box. I did this before about two years ago just by cutting the hose and then putting it back using a heat gun. It worked fine, but this time I want to do it correct. I heard this quickie is a piece of cake if you know where to press Can anyone explain how I should take this mother apart?!?!?! Maybe draw a couple of arrows on the picture?
Old Feb 24, 2008 | 06:40 PM
tbolt 460's Avatar
tbolt 460
http://www.greatnecksaw.com/product_...oducts_id=7907
Old Feb 25, 2008 | 12:47 AM
madclone's Avatar
madclone
I've seen this tool before. where should I apply it? I mean should I put the U-part around the white plastic ring? Or between the plastic and end part (the one with the hose)?what part should go where after applying this tool?
Old Feb 25, 2008 | 07:32 AM
tbolt 460's Avatar
tbolt 460
it comes with instructions
Old Feb 25, 2008 | 01:39 PM
madclone's Avatar
madclone
nice..
PS i did it w/o tool and instructions. not a big deal after all
