Heat Soak
Old Jul 13, 2019 | 06:01 PM
Adam Woolridge's Avatar
Adam Woolridge
Heat Soak
Now that the summer heat is upon us, I’m having carb/fuel line heat soak issues. If the truck sits for more than 15 min, and up to an hour afterward, it’s hard to start. I know re-routing the fuel line and adding a heat insulator helps, but what are some other tips or tricks? I think my issue is mostly the carb. If there were gas in the bowl, that hasn’t boiled out, it should still start right up. Right?
Old Jul 13, 2019 | 06:07 PM
caravaggio2000's Avatar
caravaggio2000
I haven't tried it yet, but a carb spacer made from a nonconductive material (like plastic) could help. My theory is that the fuel pump is more so the culprit.
My next step is to try gas with no ethanol.
Old Jul 13, 2019 | 06:14 PM
Adam Woolridge
Even if the fuel boils out of the lines and pump, there should still be enough in the bowl to get it started enough to re-prime everything, correct? I may try ethanol free just to try it as well. It’s just not readily available or cheap near me.
Old Jul 13, 2019 | 06:29 PM
caravaggio2000
Wawa (here in FL, but I think they are in Virginia too) is the only chain I've found that has at least one pump with ethanol free gas, 89 octane. It is about the same price as 93 premium though.
Old Jul 13, 2019 | 06:51 PM
Tedster9's Avatar
Tedster9
Gasoline itself is different than when your truck was made, once fuel injection became commonplace and carburetors a distant memory the formulation changed, called the Reid Vapor Pressure index. Some people say about a pint of Kerosene or Diesel added per fuel tank (20 gallons) helps.
Old Jul 13, 2019 | 07:48 PM
caravaggio2000
https://www.pei.org/wiki/reid-vapor-pressure
My understanding is gas actually has a higher temperature needed to vaporize now by law. Except, if you have an ethanol mix in it, then you are exempt.
Winter gas also a different blend that will vaporize at lower temperatures. I wonder if some of this may be a case of winter gas blends still working their way through gas station tanks.
Old Jul 13, 2019 | 07:59 PM
FuzzFace2's Avatar
FuzzFace2
Ok the fuel boils / expands where do you think the fuel expands to?
It cant go back to the tank because of check valve so it is pushed out of the carb into the intake .... read floods the motor.
You can try holding the gas pedal to the floor when you try and start it and see what happens.
I also posted in the other no start hot to place ice on the carb to see if the helps and if se you know where to work on.
Dave ----
Old Jul 14, 2019 | 08:15 AM
daveinva's Avatar
daveinva
Not sure where you are in VA., but I'm in Lynchburg and all I did was google 'ethanol free gas' or 'non-ethanol gas' and several places came up. Two are within 4 miles of my home and now I know where they all are. That's all I run in my truck...
Old Jul 14, 2019 | 09:50 AM
Tedster9's Avatar
Tedster9
Pure Gasoline Locations
Old Jul 14, 2019 | 11:01 AM
bigfoot22's Avatar
bigfoot22
I had the same problem a few years ago. I went with the carb spacer and haven't had the problem since.
I'm here in Martinsville VA and only know of one station that sells ethanol free gas and it's high as the premium.
Old Jul 14, 2019 | 05:33 PM
Redrokin09's Avatar
Redrokin09
This is what is what I add when I can't fine ethanol free.
Buy some of this. It helps a lot. I use it in my Snowmobile's too.
Old Jul 14, 2019 | 09:33 PM
jackietreehorn's Avatar
jackietreehorn
What happens if you floor the pedal while cranking the engine ? My 74 would never start hot unless I did this.. winter time too. I think its because the throttle plates are 100% closed with the engine off on some of these Fords.
Old Jul 15, 2019 | 12:21 PM
77explorerf150's Avatar
77explorerf150
something to look into
Old Jul 15, 2019 | 12:41 PM
fordguy2100's Avatar
fordguy2100
99% sure you can adjust that setting
Old Jul 15, 2019 | 12:44 PM
jackietreehorn
You can, the solenoid plunger shaft is threaded. You can turn the turn to increase/decrease the plunger travel thus varying the throttle. You can also adjust the idle screw as well.
Choke and fast idle should also be adjusted.
For some reason I was never able to get my Ford to hot start without pedal to the metal.
Edward Michael
Sep 17, 2018 02:42 AM
54TexasF100
21
Oct 25, 2016 01:00 PM
bigfoot22
Jun 11, 2016 09:05 PM
imlowr2
Mar 10, 2006 12:22 PM
meangenejr
Nov 6, 2004 12:38 PM
