Aerostar Ford Aerostar
Not sure
Old Jul 12, 2019 | 10:01 AM
davcad's Avatar
davcad
Not sure
Hello again guys, still mulling around trying to undo years of short cuts. I changed my upper arm bushings yesterday. The vehicle had a 1 inch dip to the front on the driver's side, the dip is still there, it make the old girl look lopsided. Any suggestions as to what may cause this. This is going to be a very long task as many of the sensor are not where they ought to be be.
Old Jul 12, 2019 | 11:52 AM
xlt4wd90's Avatar
xlt4wd90
The most likely cause of a droop would be a weaker spring on the front driver's side. That's the side that would always have a load (driver), vs the passenger side may not always have a load. You might try swapping the springs side-to-side to see if the dip moves to the passenger side.
More involved would be if parts of the frame got distorted by overloading or a hard impact in the past.
Old Jul 12, 2019 | 01:39 PM
davcad's Avatar
davcad
spring swap
Ok will try to swap out springs, on second thought will change both will use the ones from the one I purchased to scrap.
padlikehel
15
Mar 12, 2016 10:19 PM
themdgx
1983 - 2012 Ranger & B-Series
13
Dec 16, 2012 10:21 AM
racsan
Aug 31, 2012 10:29 PM
jim4
15
Feb 26, 2008 11:34 AM
