7.3 e4od code p0708. Help!
Old Jul 11, 2019 | 11:25 PM
Dustinleej's Avatar
Dustinleej
I have a 97 7.3 with a fairly new beefed up e4od.
I broke my front driveline and it banged around a little bit one night and my truck started flashing the overdrive light. When I start my truck up it will lope for a bit and stop. When I’m driving i have 2nd gear when my shifter is in second. Nothing changes when I got to first. When I shift to drive I only have 4th gear. Tranny will not shift by itself but will go in and out of overdrive. Next thing that is weird is when I put my ts chip in my truck, it stops loping and my overdrive light no longer flashes or works and it will not show any codes. I’ve replaced transmission range sensor, wiring doesn’t appear to be damaged, changed the filter and fluid and much more. I’m stumped.
Old Jul 12, 2019 | 06:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The wiring is probably damaged. If you haven't checked the harness electrically you have no idea if the harness is good or not.
Old Jul 12, 2019 | 10:37 PM
Dustinleej's Avatar
Dustinleej
Do you know where I can get a full wiring harness and not just the trs pig tail.
Old Jul 13, 2019 | 06:53 AM
z31freakify's Avatar
z31freakify
I believe the updated TRS comes with a new pigtail, i know mine did when I bought thru Autozoo.
Old Jul 13, 2019 | 07:58 AM
Mark Kovalsky
They are not available. You will have to make one, or fix the damage to the one you have.
Old Jul 13, 2019 | 11:09 AM
867.309's Avatar
867.309
Test the harness and switch together. There are variations in pin configurations, not sure what years this chart covers. Check yours for a match, but this gives you a start. This
Rollerz70
Aug 14, 2018 09:36 PM
1995F150XLT4x4
20
Jul 15, 2014 02:15 PM
princelawn
Dec 19, 2010 09:46 AM
Tenderpaw
Feb 5, 2006 08:35 AM
