I have a 97 7.3 with a fairly new beefed up e4od.
I broke my front driveline and it banged around a little bit one night and my truck started flashing the overdrive light. When I start my truck up it will lope for a bit and stop. When I’m driving i have 2nd gear when my shifter is in second. Nothing changes when I got to first. When I shift to drive I only have 4th gear. Tranny will not shift by itself but will go in and out of overdrive. Next thing that is weird is when I put my ts chip in my truck, it stops loping and my overdrive light no longer flashes or works and it will not show any codes. I’ve replaced transmission range sensor, wiring doesn’t appear to be damaged, changed the filter and fluid and much more. I’m stumped.
Test the harness and switch together. There are variations in pin configurations, not sure what years this chart covers. Check yours for a match, but this gives you a start. This
