Yeah, probably closer to 2". The F-350 needs room for the front axle to move up during suspension compression. The TTB geometry in the F-250 means that the front diff doesn't move nearly as much, so it can sit quite a bit lower. The extra lift in the rear end is mostly to compensate for the extra height needed in front.
