Transmission
Old Jul 11, 2019 | 09:48 AM
Grabbyzz3's Avatar
Grabbyzz3
Transmission
Went up camping, pulling in, notice automatic trantransmission acting up, not wanting to shift. By the time gone unhooked and everything, now wint engage at all, like its in neutral. I notice fluid pouring out from the underneath. Pretty sure tranny is shot, but Hoping i can at least get moved.
Old Jul 11, 2019 | 09:55 AM
MongooseV8's Avatar
MongooseV8
Does it engage in reverse? How did you check the trans fluid specifically?
Old Jul 11, 2019 | 09:57 AM
Grabbyzz3's Avatar
Grabbyzz3
It does not, and correction on fluid, realized it was the power steering checked....
Old Jul 11, 2019 | 10:02 AM
MongooseV8's Avatar
MongooseV8
Does the trans fluid smell burnt? Dark color with sparkles in it? Its not common to lose forward and reverse gears at once, but is possible.
Old Jul 11, 2019 | 10:05 AM
Grabbyzz3's Avatar
Grabbyzz3
Does smell burnt.
Old Jul 11, 2019 | 06:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If fluid was pouring out, it probably doesn't have enough fluid left in it to engage any gear. Does any fluid show on the dipstick?
These transmissions have a torque converter hub seal that can let go if the fluid gets too hot. Fluid will pour out, but once it cools down the seal often works fine again. You might just need to add fluid to get it going again.
Old Jul 11, 2019 | 08:03 PM
Grabbyzz3's Avatar
Grabbyzz3
There is no fluid showing on the dipstick.
Old Jul 11, 2019 | 08:32 PM
Mark Kovalsky
That is why it won't engage. It doesn't have enough fluid.
Old Jul 12, 2019 | 02:15 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Auto trans are hydraulic units, they need fluid to engage the various gears. No fluid = no movement.
Rumble phish
2004 - 2008 F150
Dec 9, 2018 07:13 PM
flatlandhillbilly
Dec 29, 2011 07:21 PM
bobaloo11
Oct 30, 2011 01:16 PM
Graygeorge
Aug 3, 2009 12:04 PM
Rich in CO
Sep 23, 2008 08:33 AM
