Starting problem
Old Jul 10, 2019 | 10:45 AM
Darren phillips's Avatar
Darren phillips
Starting problem
Have 1987 F150, 4.9 6 cyl fuel injection, truck starts and runs ok until , I shut off, it will turn over but wont start, if I wait 20-30 mins it will start, can anyone help, had it to a garage, getting fuel pressure and spark, they did change the coil as the coil was the original, only have 138,000 on odometer, Can anyone help?
Old Jul 10, 2019 | 12:00 PM
Savage19NRA's Avatar
Savage19NRA
My '92 with 4.9 had the same problem. It was a weak fuel pump. Check the fuel pressure with the engine not running and key on, it should be at least 45 psi immediately after turning the key on. Check while idling, it should be at least 42 psi, disconnect the vacuum line to the Fuel Pressure Regulator (FPR) and it should rise to 52+ psi. .
Old Jul 10, 2019 | 01:42 PM
jas88's Avatar
jas88
Could also be the pick-up coil in the distributor.
Old Jul 11, 2019 | 09:17 AM
Darren phillips
Mechanic did suggest replacing complete distributor, not sure if that will solve problem as truck will run , until I shut off, and others have done this and it still didn't solve the problem, and the 500 - 600 buck expense, and on previous post regarding fuel pump, I did have in garage last year as fuel pump wasn't working, so he wired it direct so that when turn key pump comes on,
Old Jul 11, 2019 | 10:13 AM
MongooseV8's Avatar
MongooseV8
I would look at the fuel pump, fuel filter, fuel pressure regulator, and fuel injectors.
Old Jul 11, 2019 | 10:56 AM
Darren phillips
Fuel filters
Thanks, will look at
Old Jul 11, 2019 | 01:47 PM
jas88's Avatar
jas88
When it won't start, just shoot a little starting fluid in the TB while cranking. If it starts, your problem is fuel delivery. If not, it is spark.
Brickster68
Apr 10, 2013 03:57 PM
leonphelps
Dec 6, 2011 06:25 PM
jason1300
Nov 28, 2010 04:34 PM
v8xploder
1978 - 1996 Big Bronco
Oct 12, 2009 05:46 PM
tampabandit
Oct 20, 2004 11:26 PM
