Cruise Control Problem
Old Jul 10, 2019 | 08:56 AM
quickieR's Avatar
quickieR
1993 E150 351w E4OD runs fine and cruise works well except on some long hills it will drop as much as 10 mph before downshifting and going back to set speed. Thanks for any help.
Old Jul 10, 2019 | 06:59 PM
98Econoline150's Avatar
98Econoline150
Make sure that the engine is tuned up and the transmission is in good condition maintenance-wise. Try the same thing without cruise control turned on. If the engine is in top shape and it continues to act up then look at the cruise control. You always want to start out with the basics.
Old Jul 10, 2019 | 07:15 PM
quickieR's Avatar
quickieR
Engine and trans both fine. works well off cruise. only happens with cruise on long hills
Old Jul 10, 2019 | 07:21 PM
98Econoline150
Hmm. Then I would check the servo for correct operation, check the throttle cable from the servo to the throttle body. Double check the kickdown if it is a linkage or a cable.
pbudzy
Oct 10, 2011 09:26 AM
deano-was-his-name-o
Jul 3, 2009 05:39 AM
00GT
Escape & Escape Hybrid
Jun 10, 2007 08:31 AM
merlins'92f250d
Apr 12, 2006 07:25 PM
Copper93
1978 - 1996 Big Bronco
Jul 17, 2003 11:30 PM
