2006 Ford e-150 Econoline van with 4.6 motor keeps dying
I have issues with my motor dying when I come to a stop sign. This only happens after the motor has warmed up. This all started about 3 weeks ago when I accidentally left my lights on and draining the battery completely dead. The van currently has 93,000 miles on it. There is no check engine light on the dash. The same thing happened about three years ago, when I disconnected the battery for service. But that time it corrected itself after about a week. Anybody got a clue where I should start looking? I would like to add that I drive this van everyday it is my personal vehicle that I run in my business. Thanks to all that can help
I just checked the charging gauge and I don't see any movement at idle, however when I pull up to a stop sign I can hear the RPM in the air conditioning blower slow down a little bit before the motor dies. When the motor is idling in Park I hear the motor surging maybe a hundred to 200 RPM up and down .but It has a smooth idle. And does not stall when idling in park. It has a k&n air filter and I checked it and cleaned it a couple of days ago it was a little dirty but not bad. It actually behaved after cleaning it motor did not die. But the very next day it started acting up again
Two things you should do ASAP:
-Have the alternator and charging system checked for proper operation. Most likely this is NOT an issue with that system but it would be prudent none the less.
-Check (or have checked) the Idle Air Control valve---this could be related to that device needing serviced or replaced.
And yes always best to start a new thread about another issue--tacked on questions tend to get lost or over looked.
nagetech
05-28-2011 02:11 PM
tored1971
03-24-2008 10:31 AM
