surging while on cruise control
Old Apr 2, 2006 | 08:48 PM
merlins'92f250d's Avatar
merlins'92f250d
Does anyone out there know why my '93 f250 with the 7.3 IDI would be constantl surging while on cruise?
Whe I set the Cruise, i can feel the peddel and see the tack surg usally it is only a small amount but it does it only while the cruise is on, not while using the foot feed. With a gas job I would be looking for a vacume leak, but I dont see where there would be vacume going to the cruise controler( am I wrong??)
Thanks for any help!!
Old Apr 2, 2006 | 10:41 PM
PLC7.3's Avatar
PLC7.3
Check for binding in the accelerator cable and cruise/servo cable.........
Old Apr 3, 2006 | 02:13 PM
bigoltruck's Avatar
bigoltruck
Does it do it only right after you set the cruise speed or does it occur randomly while on cruise?
Old Apr 6, 2006 | 02:43 PM
merlins'92f250d
It does it all the time when the cruise is set, if I keep my foot on the foot feed I can keep it steady, the cables are not binding and move freely,
Sure has me puzzled
Old Apr 6, 2006 | 04:02 PM
tjc transport's Avatar
tjc transport
i ain't rite
maybe a vacuum leak??
Old Apr 6, 2006 | 06:54 PM
Pigeon's Avatar
Pigeon
this happend to our cummins work truck and int ended up be the tps. not sure but mabey your fipl is out of specs?
Old Apr 6, 2006 | 07:40 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Mines been doing this and you can see the speedometer move some while on cruise. haven't found the problem yet changed speed sensor on trans. checked vaccum. check electrical. total loss on problem. Just don't use cruise anymore
Old Apr 6, 2006 | 07:41 PM
jdemaris's Avatar
jdemaris
Cruise-control surge
I've never had that problem (yet) with either of my Ford diesels, but it's happened on two of my GM diesels. Both times it was a bad vacuum-motor servo - that hooks to the throttle. I assume the surge evolves because the pod gets a leak, so it won't hold a steady position, and when the vehicle speed drops a little, more vacuum is sent to it - and thus the surge.
With my Fords, I don't even know if they use vacuum pods for the cruise-control - I've never had to look that close yet. I've got an 85 with a 6.9 and a 94 with a 7.3 turbo.
Old Apr 7, 2006 | 01:21 AM
edsofish's Avatar
edsofish
Hello Merlin, I was just thinking that maybe a faulty dump valve or a crack in the printed circuit board on the cruise amplifier.
On my '85 F-250 6.9 the actuator is both electrical and uses vacume.
I recently fixed the coffee can that had a small defect in the seam. If I had to look at it I would say that it was fine, but, when I put the vacume to it it would leak badly. I finally saw the area that the solder was not sealing the seam and used rosin core solder and my soldering gun to fix it. I did most of the seam just to make sure.
On my '85 Mercedes 300 D, the most common problem with cruise control is the cruise amplifier. It gets cracks in the PC board and causes intermittent cruise such as yours. The fix is to remove the board and resolder all the solder lines and connections.
Anyway, just a few thoughts. Hope it all works out.
The best to all. -ED
Old Apr 12, 2006 | 07:25 PM
adam hafer's Avatar
adam hafer
this may sound stupid but are your tires of stock size. When I put on 38" tires I would turn on my cruise and it would do the same thing. Even tho that was a very big change in tire size, I found even a little bigger would do that to my truck. But mine is a 99' don't know if its the same cruise setup.
ugh3012
Oct 24, 2016 06:19 AM
02GrayPowerStroke
1997 - 2003 F150
Oct 10, 2016 06:01 AM
BBuford1962
16
Feb 9, 2016 04:22 PM
mgraveman
Feb 26, 2013 08:53 AM
leardvr
Jan 5, 2009 05:10 PM
