Carburator too big?
Old Jul 8, 2019 | 02:06 PM
Stephen Hayhurst's Avatar
Stephen Hayhurst
Carburator too big?
I just bought a 1976 f250 with a supposed 390fe. The previous owner installed an Edelbrock 1407 750 cfm carburator. Is this too muvh carburator for that engine? I'm getting roughly 7mpg and am wondering if this might be a possible cause.
Old Jul 8, 2019 | 02:11 PM
440 sixpack's Avatar
440 sixpack
That's plenty of carb but it shouldn't be a big problem if it's in good working order. well as good as Carter works anyway.
Pull a couple plugs and see what they look like. there are many causes for poor fuel mileage.
What is the build on the engine? maybe 7 is as good as it gets. the mild built 428 CJ in my high boy is running perfect and I bet 8 is as good as I'm getting.
Old Jul 8, 2019 | 02:13 PM
Stephen Hayhurst
I just swapped out the plugs. Gapped every one of them to .034
I would have thought 12mpg would be normal but maybe you're right. 7 is as good as it gets???
Old Jul 8, 2019 | 02:48 PM
caravaggio2000's Avatar
caravaggio2000
Depends how it is built, but my 390 gets around 12-14. I do have a 600 cfm Holley. Did the old plugs look like a rich condition? is this 2v or 4v? Auto/manual? Rear gear ratio?
What engine does your vin say you have?
Old Jul 8, 2019 | 04:39 PM
Tedster9's Avatar
Tedster9
Post a clear close up pic of a couple spark plugs. Not the new ones, the old ones.
Unless somebody knew what they were doing, and spent some time at it, it's almost certainly not getting anywhere near the highway mileage it's capable of. Not that it will be anything to write home about when tuned-up but there's no sense wasting fuel. 7 mpg to 14 mpg is a 100% improvement, not bad on a percentage basis anyway.
Old Jul 8, 2019 | 11:54 PM
SlikWillie's Avatar
SlikWillie
Unless you are driving a really hopped up 390 with a wild cam and high compression pistons, I'd say yes, you are running too big of a carb. A properly tuned 650cfm carb is going to be much better for a mildly built 390. But if you are ALL stock, a 600cfm. People over carb engines all the time. Everyone thinks they are improving their performance with a 750 carb and really they could be doing much better with a smaller carb. Just speaking from experience here.
Old Jul 9, 2019 | 12:49 AM
440 sixpack
It is an excessive carb but if it's jetted right it really shouldn't effect fuel economy under normal driving conditions. a little over carburation effects throttle response more than anything else. but I agree a 650 would be about ideal if it's stock.
If something is going on the plugs should be black, or at least dark.
If the engine is basically stock it should get 10 or so. I don't think the 390's we had around here ever got much better than that from the day they were new. stock 360 2v was 10 or 11.
the modern fuels don't help anything either.
Old Jul 9, 2019 | 11:25 AM
Tedster9's Avatar
Tedster9
F250 is heavy, with aerodynamics of a brick. How much more does it weigh than F100? I seem to recall the official hwy mpg was around 14 or 15 back in the day. If you can target Ford's official mpg hwy rating that will always indicate you're getting close to a decent tune. The problem with a poor tune is it fouls plugs out and this just compounds the problem, and wastes gas without improving performance. These trucks will never get stellar fuel economy but there's no sense wasting half of it out the tailpipe and diluting engine oil, wearing piston rings and bores excessively.
Old Jul 9, 2019 | 12:23 PM
440 sixpack
It's not the weight as much as the gearing. if you have a 3/4 ton with 3.73's or 410's you're revving at 55 mph.
I have never ever seen a carburated big block f-250 get anything close to 15 .
66crawler
Dec 10, 2012 09:15 PM
72Highboy4x4
29
Sep 14, 2012 06:13 PM
NW 150
37
May 1, 2012 09:06 PM
albcasummit
May 25, 2006 12:29 AM
Deebo78
Jan 26, 2003 09:14 PM
