manual transmision identification
Old Jul 8, 2019 | 11:00 AM
jdmcb's Avatar
jdmcb
I am about to do an engine (5.8L) swap from a 1992 f250 (Automatic) to a 1989 (5.0L) f250 (manual.) This is going to be a plow truck for a small farm. I know it has a 5speed od. How do identify if it is a Mazda transmission, and if it is, will it bolt up and work for this application.
Thanks, any input is appreciated.
Old Jul 8, 2019 | 12:37 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes it will. The 300, 302 and 351W have the same bell housing pattern. Does it have a “granny” first gear?
Old Jul 8, 2019 | 12:48 PM
jdmcb's Avatar
jdmcb
I don't know for sure. I don't have a lot of information on the 88. I do have a good E4OD, but was thinking with the electronic part of the tranny, this would be more difficult.
We will just use the truck for occasional plowing and running to the dump.
Old Jul 8, 2019 | 12:57 PM
85e150's Avatar
85e150
Mazda: Horizontal/vertical grid ribbing:
M5OD Transmission Sale | M5R2, M5ODR2, Bronco, F150, F250
ZF: Diagonal ribbing:
https://claz.org/classifieds?q=zf+5+speed
Bring the 5.8 and automatic over, along with controller and harness. Serving suggestion.
Unless you are going to put a carb on that 5.8 you have to transplant the ECU and harness anyway.
Old Jul 8, 2019 | 02:29 PM
jdmcb's Avatar
jdmcb
Thanks, Its the Mazda trans. I will have to rethink my plans. Would it be easier to buy an Automatic floor shift kit or change steering columns?
Old Jul 8, 2019 | 06:21 PM
85e150's Avatar
85e150
IMO floor shifter. You already have hole in the floor. It's cables anyway,
Old Jul 8, 2019 | 08:22 PM
rla2005's Avatar
rla2005
Given the above end goal I think you will be fine with keeping the Mazda transmission. I highly suggest sourcing the correct 5.8L and manual transmission PCM.
Old Jul 9, 2019 | 06:07 AM
jdmcb's Avatar
jdmcb
Would the PCM for the 1988 5.0L work with the 5.8L? The 5.0 L was fuel injected. I kind of like the idea of having a Manual, but I don't want problems down the road.
Old Jul 9, 2019 | 07:18 AM
rla2005's Avatar
rla2005
Some will say it worked fine for them, others not so much. Knowing a computer designed for a smaller cubic inch motor may lead to a lean condition I would suggest getting the correct one for your engine/transmission. You may be able to keep the 5.8L computer happy by using the MLPS set to neutral then tie wrap it away from everything. I do not think no connection to the solenoid pack would trigger a Check Engine Light (CEL), but it will fail the KOEO tests/CM display. Not a deal breaker, but a minor annoyance.
Eric Ramirez
Jun 30, 2019 04:19 PM
tfowler306
Sep 25, 2007 08:09 AM
mdjohnson
Feb 3, 2006 05:16 PM
frenchf250
Dec 24, 2003 12:46 AM
Will Stewart
Nov 8, 2002 12:52 PM
