Help with 2014 PS Tuning
I would like to do a delete and tune and replace the intake with my main goal being to increase my MPG's.
I have very little knowledge about all of this other than what I have been able to aquire from friends who have deleted their 7.3s.
It has been suggested that I get a S&B intake, 5" mandrel bent stainless exhaust, and a tuner.
Would like to hear thoughts and opinions on steps to take to increase MPG. I wont be towing anything at this time but intend on getting a 5th Wheel in a couple of years.
Thanks for and guidance and suggestions.
The 7.3L didn't have SCR, a DPF or an EGR cooler. These trucks are quite a bit more complicated.
The 6.7L stock filter setup is good unless you are planning for a high HP increase tune.
You have a lot of research to do to make an informed decision that works for you. It's difficult to answer exactly what you need to do for your use case. It's easier to answer specific questions based on a narrowed list of options.
I don't think you need the intake or the 5" exhaust. There is also keeping the EGR cooler or removing the EGR cooler, which requires a kit. Both are options.
The EZ LYNK and SCT X4 tuning hardware is the more popular options today (that I am aware of) with custom tunes (important: don't buy canned tunes).
I am definately not in love with the lift and big tires as I find the ride to be stiff (every bump in the road feels like a speedbump) and 11 MPG isn't going to cut it for me with the traveling that I bought the truck to do. For me, at 51 years old, the fuel efficiency and comfort trump the looks although, I do think my truck looks pretty darn good.
I am getting ready to make a 3500 mile trip in it next week and will see what I get calculating the MPG manually. I notice that with the lift and tires my speedo is showing about 5mph slower than what the truck is actually traveling. I'm sure this is causing an inaccurate MPG reading on the dash. I also have been enjoying the power and have been a bit harder on the pedal because of it. I will try to watch the RPM's on the trip and see how much improvement I can make. This will at least be a starting point.
Give us your current tire size (completely as in 275/65R20 or whatever it is) and stock tire size.
Forscan (a super easy computer program to use) can set your tire size to something closer to what you have. Only factory options are available though.
speedo calc
I added a picture of the truck to my album.
The tires I have are the KO2s and they are brand new. I am not aware of the history of these tires but when I was researching what to replace the old Nittos with the KO2's
seemed to have good ratings for an all weather.
I am out of town until Thursday and away from my truck so I can’t check the factory sticker to get the wheel size on the door until I get back.
Did I screw up getting the KO2s?
The tires on the truck right now are LT325 60R 20
I doubt it came from the factory with 20s given the aftermarket lift and aftermarket wheels.
I will get the info from the door when I get back on Thursday.
It looks like a Lariat trim so it's possible it came with 20" factory wheels.
I learned that minor changes quickly impact MPG on these heavy trucks. I lost 0.5 MPG going from Nitto Terra Grapplers to Toyo Open Country AT2 and lost another 0.5 MPG replacing those with the Cooper ST MAXX. All 295/70 R18.
Another thought towards your long term plan is to confirm those aftermarket wheels are rated for a heavy fifth wheel. It may be that you decide once this set of tires are worn out that you drop to a smaller tire size and return to stock height.
I think you need to get some hand calc numbers on paper to confirm your actual MPG and get the speedometer corrected as that helps with transmission shift strategy as well.
Here is an example of my MPG when all stock, emissions and the aggressive Cooper tires on factory XLT wheels. This is when I was daily driving it, "T" is for towing (8,000 lbs).
I am deleted now and I have increased to the low 14 MPG (sometimes 13.7) but I didn't delete looking for more MPG or because I specifically wanted to. After spending $1,400 on various emissions repairs and later in derate pending another $1,000 emissions repair (what was next, the $4,300 DPF?), I threw my hands up and resolved my issues, even two unrelated issues Ford never could resolve. What I'm trying to say, you're never going to see 20 MPG for example and deleting is around a $2,000 adventure with the necessary custom tunes. My average savings in cost per mile (just considering MPG increase) so far is $0.025 so if I was removing emissions just to increase MPG, it would be 80,000 miles just to break even if fuel costs remained the same average (one year data sample).
12.2
11.3 T
13.1
12.3
13.1
13.1
12.4
11.4 T
13.2
13.5
12.7
12.6
12.8
I really appreciate your input on the emissions as it just saved me a couple thousand $$ on doing a delete that would have resulted in little MPG increase. The reason you deleted your truck makes perfect sense and I will take that knowledge with me going forward when issues with the emissions system start to raise their ugly head.
I'll post back with an update when I get to FL around the 13th.
Starting latest first...
15.89
15.81
15.23
15.40
15.47
15.32
14.32
14.78
14.48
15.14
16.78
15.34
15.51
15.54
15.16
14.51
14.82
13.89
These go out to late March where the MPGs drop because of the winter fuel. These all include regens. I have slowed down some to get the MPGs up and carry my money further at the pump. A lot of my driving is country roads with hills and stop signs. I have an expressway I take into work and driving in the city where I work is about 2 miles off the expressway to give you an idea of a daily driven stock truck's MPG.
https://www.ford-trucks.com/forums/1...ut-delete.html
I have compared it to my GPS and Goggle Maps and it's off 2 mph.
