Wheel Studs?
Old Jul 3, 2019 | 08:17 PM
Fleetwood271's Avatar
Fleetwood271
Wheel Studs?
Started to put my new wheels on today and found that the new rear tires will rub on the inside. So...I need some spacers. I believe 3/4" spacers will work fine. I will also need to buy longer wheel studs.
Can anyone tell me what size wheel studs go in the rear of a 1969 Ford F100?
Thread size?
Shoulder?
Knurl size?
Old Jul 3, 2019 | 11:00 PM
mrpotatohead's Avatar
mrpotatohead
I wouldn't recommend using spacers, I've seen stud failure due to this.
Old Jul 4, 2019 | 03:54 AM
GaryKip's Avatar
GaryKip
The studs SHOULD BE 1/2" X 20 threads per inch. Lug nut torque is 70 - 115 LBS. I found the length, 1 13/16'. The part number MAY BE: C6AZ 1012-A
Old Jul 4, 2019 | 10:44 AM
Fleetwood271
I'd rather not, but the only way I see to use these new wheels and tires is to add a spacer. The tire is rubbing the inside of the fender well. It's less than 1/8" from the little lip at the bottom of the fender well, but the indention on the fender well that you can see from inside the bed is actually rubbing the tire. In fact, when coming down off the jack, the truck will not come all the way down due to how much the fender is on the tire.
Old Jul 4, 2019 | 10:46 AM
Fleetwood271
Thank you for finding this Sir. I appreciate the help.
I am also considering buying a couple of 3/4" adapters, that do not change the lug pattern. Basically spacers with their own lug bolts already installed. That way I wouldn't have to use longer studs.
Old Jul 4, 2019 | 09:41 PM
my72's Avatar
my72
I used a 1/2" spacer and the Moser studs. No problems.
Old Jul 4, 2019 | 09:50 PM
Fleetwood271
Thanks for the info. Do you know where you bought the 1/2" spacer and the Moser studs?
Old Jul 4, 2019 | 10:29 PM
my72's Avatar
my72
Both at Summit, lots to choose from on the spacers.
Moser Engineering 8010 - Moser Engineering Wheel Studs
Old Jul 5, 2019 | 10:31 PM
Fleetwood271
Thank You for the information.
bankog1
Dec 22, 2022 09:27 AM
nix4x4
Jan 13, 2017 03:33 PM
Jeff55F100
Nov 7, 2011 04:56 PM
fusion1127
Oct 5, 2011 04:03 PM
pipman76
May 29, 2009 11:42 AM
