Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Help 351w identify!
Old Jul 3, 2019 | 07:15 PM
69Machone's Avatar
69Machone
Help 351w identify!
Hi trying to I.D. my block to get my project going casting is
C90E 6015 B 8 and some other # 0b25 . It's a 2 bb 250hp i think and up to 300 hp on a 4bbl?
Old Jul 3, 2019 | 09:39 PM
85e150's Avatar
85e150
Looks like an original casting number for the first 351Ws. Casting numbers here:
Kelly hotrod - Ford Engines Page 2
0b25 is probably the date code. "0" for 1970, "b" for February, "25" for the 25th of the month. They let the blocks sit for a while after casting, so your block probably ended up in a mid to late production 1970, for any model using the 351W.
Scroll down for more on casting and date numbers:
https://classicmustang.com/decoding-part-numbers/
Looks like the 250/300 ratings were the advertised HP for '70.
What are you doing with your motor?
Old Jul 4, 2019 | 09:28 PM
69Machone's Avatar
69Machone
Thanks for the info I just got it trying to determine its integrity gonna check if it turns and then compression based on the results will weight what I should do with it use,rebuild or sell.
Its hooked up to a c6 transmission but I desire to get a manual, got a 3speed 69 toploader sitting in the garage but not sure if it can handle a 351w. Just the start of the project gonna do a ground up 69 mach 1 Mustang I know this is a truck site came here because I usto get alot of great info on my ford pick up needed some help
Blue80
May 28, 2009 09:44 AM
oldranger6869
Mar 30, 2008 02:39 PM
j_rok13
Jan 8, 2008 07:11 PM
banky
Jun 13, 2006 08:15 AM
rangersvt04
Sep 27, 2005 11:10 PM
