Help doing trans flush
Old Jul 3, 2019 | 05:12 PM
Kenny Hernandez's Avatar
Kenny Hernandez
Been doing a flush on my trans lines had it flushing for like 4 days and keep having black little plastic peices coming out of it no stop some times none and other times alot just cant figure out from where. Got new trans been gone through and converter new trans cooler just need to get it cleaned up before install plz help
Old Jul 3, 2019 | 05:22 PM
87crewdually's Avatar
87crewdually
Did you have a trans go bad and now you're installing a rebuilt one?
If so you may have junk stuck in the cooler. This is why many rebuilders require a new cooler to be installed.
I would disconnect all the lines. Then fill the line with brake cleaner and blow it out with shop air backwards to dislodge and clean it out. Reality though if the cooler has that much crap trapped in it I'd rather replace it.
Old Jul 3, 2019 | 05:43 PM
Kenny Hernandez
Yes had a trans go bad went through it completely rebuilt it with a few new goodys. Has a new trans cooler in it and still pulling crap out
Old Jul 3, 2019 | 07:01 PM
TooManyToys.'s Avatar
TooManyToys.
But were the lines, radiator cooler flushed, and the trans remote filter changed.
Old Jul 3, 2019 | 07:42 PM
Kenny Hernandez
Yes all that was flushed and filter has been changed a couple times
Old Jul 4, 2019 | 10:20 AM
bismic's Avatar
bismic
What flush procedure have you been using?
Old Jul 4, 2019 | 02:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you want the new trans to last you need to replace the radiator (to replace the internal trans cooler) and the external trans cooler. You can NEVER flush all the crap from a failed transmission out of the coolers. Sooner or later some piece of the old trans will break loose and find it's way into the new trans where it can grenade that transmission.
Old Jul 7, 2019 | 10:50 AM
F350 1990's Avatar
F350 1990
I'd say you have better than 50/50 odds "something" has made its way back to that otherwise rock solid tranny.
In theory the external filter should catch "some" things, but it's a terrible design to begin with ---- I'd go with an upgraded 6.4 trans pan and upgraded (internal) filter arrangement too....................
Old Jul 7, 2019 | 02:24 PM
Mark Kovalsky
It's a bypass filter. It only sees 10% of the flow to the cooler. So by design 90% of the junk in the ATF does not go through this filter.
Excellent suggestion.
SoCalAngler
Jan 12, 2018 10:19 PM
Supercab
Dec 14, 2011 07:55 PM
itsjustdan26
Jun 18, 2010 10:30 AM
Talyn
Aug 9, 2009 12:46 PM
mudinford
Jul 22, 2004 12:31 PM
